Question about Lenoxx Electronics CD-149 Cassette/CD Boombox
Where ccan I find parts numbers and/or replacement belts
SOURCE: I need a new power cord
i need a power cord that plugs in the back, cant i just buy one local somewhere
Posted on Dec 08, 2009
SOURCE: The cd player part of my model CD 102 combo radio,
Since the motor tries to start up, I don't think it's a motor problem. I think that the problem is at the lens; it can't read the cd so it does to stand by mode. I suggest you a cheap solution. Buy a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl
alchohol) at a specific place (like small brush) on the disk surface and play this disk. That way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropylic alchool to clean up the cd lens manually.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 12, 2010
SOURCE: Lenoxx compact disc player stero cassette
Does it fail on AC power, too? Motors draw a lot of current. Batteries may be weak.
Posted on Jan 18, 2011
SOURCE: I need a replacement antenna
try to buy at any electronics shop or at any DIY shop
Posted on May 23, 2011
SOURCE: Belts are broken for the
http://www.studiosoundelectronics.com/cassette.htm
You can remove the damaged one and measure it and this site on the link above provides generic replacement
Posted on Sep 27, 2011
Jun 08, 2015 | Lenoxx Electronics CD-149 Cassette/CD...
Jan 03, 2012 | Lenoxx Electronics CD-102 Cassette/CD...
Sep 20, 2011 | Lenoxx Electronics CD-102 Cassette/CD...
Sep 07, 2011 | Lenoxx Electronics CD-102 Cassette/CD...
Aug 13, 2011 | Audio Players & Recorders
May 23, 2011 | Lenoxx Electronics CD-102 Cassette/CD...
Mar 01, 2011 | Lenoxx Electronics CD-149 Cassette/CD...
Jul 11, 2009 | Lenoxx Electronics CD-149 Cassette/CD...
161 people viewed this question
