Question about Lexmark P3150 All-In-One InkJet Printer
Vista driver - Lexmark P3150 All-In-One InkJet Printer
Put in card, no recognition. Windows 7. Could I use a Vista driver?
Vista and Windows 7 drivers are often cross-compatible. The Vista driver should work.
Feb 28, 2011 | Toshiba Satellite M45-S269 (PSM42U016006)...
Epson Stylus CX6000 prints but won't scan in Vista. Works in XP
Sometimes the newer print drivers don't do everything the older ones do. make sure you have a Vista print driver, and that the Vista print driver has that function (my HP Vista driver wouldn't scan for about the first year until HP finally updated the driver) Make sure you have the latest release of the vista print driver. if the problem is the vista print driver, sometimes you can get lucky by running/installing an XP driver on a Vista machine, in XP compatibility mode (right click, compatibility)
Jun 12, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Ei-3103 vista drivers needed
download AC97 sound driver for vista and realtech ethernet driver for vista these are the to most common,  and install them
May 04, 2009 | Computers & Internet
Free CQ40 webcam driver for vista version
sir i want all drivers hp compaq presario Cq40 drivers give me
Apr 11, 2009 | HP Compaq Presario CQ50-110US Laptop
Vista driver for mustek scaner 1200 ED
There is no official driver for mustek 1200 for vista, due to it's age, but you can try installing the one intended for XP from: http://www.mustek.com.tw/Download/driv_scanr/europe/1200ed.html .
As far as I know, you don't need special drivers for HP Deskjet printers in vista, due to system having integrated drivers. But in case that the system doesn't recognise the device you can try with xp drivers (since there are none officially for vista) from: http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&dlc=en&cc=emea_africa&lang=en&softwareitem=dj-14939-2&os=228&product=375447&
Soundmax vista driver:
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Analog-Devices-SoundMAX-AD1988-Vista-Driver-610026110-WHQL.shtml
Mar 22, 2009 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Canon pixma500
This product can be used with Windows Vista.
  • To use it with Windows Vista, you must install the driver software for Windows Vista.
  • The Windows XP drivers for your product cannot be used under Windows Vista.
  • Easy-WebPrint and PhotoRecord do not support Windows Vista.
Upgrading from Windows XP to Windows Vista :
Before upgrading your OS from Windows XP to Windows Vista, delete / uninstall all the Windows XP driver software first; then, upgrade the OS to Windows Vista and install Vista driver software.
If you have already upgraded your computer's OS to Windows Vista :
Delete / uninstall the Windows XP drivers before installing Vista drivers.
I hope it helps!!!
Nov 22, 2008 | Canon Pixma MP500 All-In-One InkJet...
Vista Driver
try running the driver setup program in Vista in compatibility mode.
http://www.devicedriverfinder.com/blog/device-drivers/how-to-install-xp-drivers-in-vista
Oct 14, 2008 | Nikai DV7000 Camcorder
WIndow vista have driver?
I have had the same issue, Try this on an xp machine with driver loaded for dc1250 share this printer and then on the vista machine brouse the network and double click the shared printer on the xp machine and the driver should load and vista will print using the xp machine as a print server.
Les
Jul 23, 2008 | Xerox DocuColor 12 Printer
DRIVERS FOR INTEL CS630 FOR VISTA
need vista drivers for intel cs630
Jul 16, 2008 | Intel CS630 Webcam
Bluetooth class 2 dongle
here are some sites in which the bluetooth dongle drivers for vista are available just download it from here for free........
www.exwell.com/support.html
www.telusplanet.net/public/wladykad/
www.dev-toast.com/2007/01/05/uncrippling-bluetooth-in-vista-rtm
www.dirfile.com/medieval_bluetooth_diagnostic_tool.htm
www.fulldownloads.us/free-full-download-bluetooth+usb+dongle+driver+vista-crack-serial-keygen-torrent.html
yzoo.co.uk/search/web/mikomi+bluetooth+driver+vista.html
www.radarsync.com/vista/vista_more.php?result=400
www.mobilefun.co.uk/cheap-jabra-bluetooth-dongle-vista-driver-download.htm
www.bonphi.com/download.html
www.nodevice.com/driver/company/Gigabyte/Bluetooth_network.html
Feb 08, 2008 | Microsoft Windows Vista Ultimate Edition
Lexmark P3150 All-In-One InkJet Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
