SOURCE: MFP sharp ar-m420u/mx-2300g new installation.
Change IC connector on toner unit with two screws neer gears of toner cartridge.
SOURCE: which toner do I use for sharp AR-M420U/Mx 2300g
AR-450ET
Testimonial: "I found this fixyah from a friend and I glad you are doing a nice job. I was very messed up with toner type type nobody new it the type. Thanks again"
SOURCE: my AR-M420U sharp printer/copier displays (call 4
problem is in the crum. re insert the cart. into developing.
SOURCE: after installation my sharp ar-m420u
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
