Singer Inspiration 4220 Mechanical Sewing Machine Logo
A
Anonymous Posted on Jan 25, 2014
How to get new bobbin holder in place on singer inspiration 4220
5 Related Answers
Anonymous
  • 323 Answers
  • Posted on Jul 01, 2008
SOURCE: Singer-Inspiration 4220/4228
Send this machine back where it came from! machine. You have described a timing problem which you can not and should not need to do.
Change the needle first and test it to be sure the needle still hits on the hook. If it does,follow the above instructions. If it no longer hits then it's possible it is not as serious as I first thought.I'm not sure if the bobbin keeps coming out or the bobbin case(the plastic part the bobbin sits in) comes out.If it is just the bobbin, insert the bobbin in the case and pull on the thread. The bobbin should turn COUNTERCLOCKWISE. If it turns the other way, turn it upside down and try it again.
If it is the bobbincase,then Remove the needle plate and take the bobbin case completely out. On this machine there is a small lever which holds the bobbin case in position. Looking down on the bobbin case the lever is located at about 11 o'clock and has a small slot in it. It is also probably spring loaded which means it is not easy to turn without a small screwdriver. Insert the screwdriver in the slot and turn it to the left. Lift out the bobbin case and Carefully examine it for any nicks, scratches or rough spots. If you find any, they will need to be removed with an emery stick and or a sharpening stone. Buff with a very fine steel wool for total smoothness.
To replace the bobbin case use the screwdriver to open and hold the lever open while you insert the case back in. The straight part of the case will be on the right and you need to place the case so that the circular part rides on the slight grove in the hook.(The metal thing it sits on). Once you have it in place you can release the lever you've been holding open . It should fit over the edge of the bobbin case and not allow it to come out. Rethread the machine and turn it by hand a few times to see that it is working properly. Good luck!!!
sewman7
Anonymous
  • 139 Answers
  • Posted on Apr 13, 2010
SOURCE: I have a Singer inspiration and am having the
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Anonymous
  • Posted on Apr 22, 2010
SOURCE: WHEN TRYING TO PICK UP THE LOWER BOBBIN THREAD -
It is not picking up the bobbin
Anonymous
  • 1788 Answers
  • Posted on Oct 27, 2010
SOURCE: i have an old singer fashion mate my mother gave
I don't know if you have the 237 or the 257 model but I think that they are very similar. You can download the manual for the 237 for free at www.singerco.com, under the customer support tab. Enter 237 in the box for instruction model #, Look at page 14 and you can see if you are doing it right, because it looks like it will snap in place once you put it in correctly. If, you are, you may have to replace some parts, hopefully not. But, they can be had a www.sewingpartsonline.com and other places. A hard ciopy for the 257 is $15 from Singer. Good luck
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Jan 28, 2012
SOURCE: singer 9410 Bobbin Repair
it sound like the machine needs to be serviced by a sewing machine repair tech
2helpful
2answers
I would like to order an owners manuel for a Singer Inspiration model#4220 thank you
well you search --singer operators manual for inspiration model 4220 -- and then down load the pdf version
fixya site doesn't take orders
2answers
How do I put a bobbin holder securely back in a singer 4210?
Here's a YouTube video that shows how to set up a Singer Inspiration. Hopefully it is helpful.
https://www.youtube.com/watch?v=U9In9uutwt0
Singer Inspiration threading
Bottom thread pull out after stitched What is my mom doing wrong
try a new needle
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
try adjusting the top thread tension
if these suggestions don't help then it would be a good idea to have the machine checked
2helpful
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Singer 4220
try changing the needle
rethread the machine top & bobbin
check to see if the thread has come off the thread take up lever
clean under the needle plate & in the bobbin area for lint & thread
2answers
Singer inspiration thread wraps around bobbin seat while sewing
it sounds like you need a new bobbin case. and it would be a good idea to have the machine serviced
What bobbin should be used for a singer inspiration moder 4220
Normally it is a #15 or 15J. Your manual should tell you or you can go online at singerco.com and look under support for a free download of you manual. I checked the Singer site and you may have to have a "surefit" bobbin that is exclusive to Singer. You can call them at 1-800-4singer
2answers
WHEN TRYING TO PICK UP THE LOWER BOBBIN THREAD - HAVE NOW BROKEN TWO NEEDLES. THEY BEND AND SNAP AS IF THE MACHINE IS OUT OF SINK WITH ITSELF.MY MACHINE IS A SINGER INSPIRATION 4220 . (I DONT REALLY KNOW...
Make sure the needles are installed with the flat side facing the back of the machine.
Open the bobbin area and hand walk the needle down to see what it is hitting.
Check the bobbin case and shuttle to be sure they are in place.
Needles can also bend and break if they are too small for the thickness of the fabric.
2answers
I removed the positiong plate
I removed the posiotioning Plate(A). Singer Inspiration 4205. How can I get it back in?
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
