Question about Samsung PN Televison & Video
50 inch samsung plasma tv turns off
When I turn on my television, it initially is fuzzy and makes a a loud buzzing noise, then turns itself on and off a few times before finally turning on for good and working normally. The process of turning itself on and off last for aprox 1 minute.
Posted by Mike Hutman on
5 Related Answers
Anonymous
  • 18 Answers
SOURCE: Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
Posted on May 31, 2008
Anonymous
SOURCE: Plazma TV buzzing noise
The transformer is resonating. Get it replaced, Don't do it yourself.
Posted on Sep 27, 2008
Anonymous
  • 124 Answers
SOURCE: Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Posted on Mar 03, 2009
Anonymous
SOURCE: my 50 inch samsung plasma tv turns off and on by
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
Posted on Dec 19, 2009
Chi Chu
  • 8457 Answers
SOURCE: my vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Posted on Jan 08, 2010
My phillips is making a loud buzzing noise, no picture, then it shuts off
presuming it has one two choices: contact Philips (good luck there) or Google the model number with "color wheel"
Oct 31, 2012 | Philips 50PL9126D/37B 50" DLP TV
Loud humming noise from under my Tahoe. 2WD
The noise is your fuel pump which should hum, but not buzz. It is going bad & will need replaced soon.
murf427
Aug 02, 2012 | Chevrolet 2001 CHEVROLET TAHOE Chassis...
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Loud buzzing noise when turning on
It sounds like a bad internal connection or a component failing. If the picture still is very good take it to a known good repair shop.
Nov 21, 2008 | Televison & Video
Samsung 7178 buzz noise
Is this buzz from the speakers?
Is this buzz from the set itself when the sound is turned down?
Is this buzz a low pitch sound?
Is this buzz a high pich sound?
Does this buzz vary in loudness with the volume control?
Does this buzz change in level from time to time?
You should post the details and the circumstances of use in order to give some idea of the conditions.
Jerry G.
Apr 16, 2008 | Televison & Video
Spngbob TV Makes buzzing noise when plugged in and wont turn on
Bad horizontal driver or output transistor/trnsformer. Look for serious service for this set...accordianman
Oct 19, 2007 | Emerson SpongeBob SquarePants TV
TV will not turn on
Probably needs a new HV Splitter block, they are very difficult to replace and can usually be accessed thru the front behind the speaker grill and behind convergence board.
Mar 18, 2007 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
78 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
