When I boot laptop the Toshiba logo comes up then disappears leaving a blinking icon in top left corner - any suggestions?
SOURCE: Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
SOURCE: Toshiba won't boot
You can boot from XP cd.
When prompted..press [R] this will launch recovery console.
Choose your windows installation (typically by pressing [1] press return..
When prompted for password type chkdsk /r
Press return..Windows will fix errors..type Exit and press return..
Let me know if that helps.
SOURCE: L355 Satellite Shows Toshiba Logo then goes to
You need your Vista disk to re-install Vista.
If you don't want to go to the expense, download and install Ubuntu, its a free opterating system and now on version 10.4, its pretty good.
hi, i have same problem with my friends., if you want to try this some steps:
click here to view the content: http://fixtips4u.blogspot.com/2011/12/toshiba-nb255-n245-i-get-blank-screen.html
SOURCE: why do i have an intermittent problem with my laptop freezing up during startup? startup?
You may have a bug. You may start by going to control panel and see how many programs are trying to start up at the same time. When my laptop does that I normally go to the control panel and stop programs and keep them from turning on at start up. you really dont need all programs to start up at the same time. This may cause freezing and longer times to start at start up.
