Televison & Video Logo
Question about Mitsubishi CS-35505 35" TV
What is the weight - Mitsubishi CS-35505 35" TV
1helpful
2answers
I have a 2010 Lancia Musa 1.4t. How much weight can I tow?
Most towing advise works to the 85% rule. As long as the maximum weight to be towed is 'Not' greater than 85% of the vehicles maximum 'kerb' weight, (maximum gross weight).
The Musa should not pull over 1000kg, (1 metric tonne). A braked trailer will allow that weight to rise by about 200kg.
1helpful
Not sure if first attempt went through so i will try again. We were moving a sligh grandfather clock and the brass weights fell and the weights inside came out which weights go in which brass?
with most old clocks the weights were a means of moving the gears in the clock instead of using a spring
If I am right , to wind up the clock you pulled one lot of weights down and the weights then slowly changed positions from one up to one down
normally the lh weight is the wind up weight and is slightly lighter the than the rh weight
your problem will be determining the correct weight for the rh side as too heavy and the clock will gain time and too light will loose time
Dec 10, 2015 • Watches
What is the difference between static weight and working weight with massage tables?
It's a good question as it makes a difference. Static weight is basically the weight that the massage table can hold while it's stationary with the weight spread evenly over the table. Working weight is the added weight that the table can take with extra weight, pressure and load from the therapist.
Aug 13, 2012 • Furniture
Kitchen scales & weights
Hope this helps,plz let me know
JonnieC
Weighing 1
006s1.gifWeigh 1 2 3 on the left and 4 5 6 on the right
If the weights are even go to Weighing 2a
If the left side is lighter go to Weighing 2b
If the right side is lighter go to Weighing 2c
Weighing 2a
006s2a.gifWeigh 7 on the left and 8 on the right
If the left side is lighter then weight 7 is the answer
If the right side is lighter then weight 8 is the answer
Weighing 2b
006s2b.gifWeigh 1 on the left and 2 on the right
If the weights are even then weight 3 is the answer
If the left side is lighter then weight 1 is the answer
If the right side is lighter then weight 2 is the answer
Weighing 2c
006s2c.gifWeigh 4 on the left and 5 on the right
If the weights are even then weight 6 is the answer
If the left side is lighter then weight 4 is the answer
If the right side is lighter then weight 5 is the answer
How do you program users?
Storing and Recalling Weights
1. Your scale can store and recall up to 5 weights. If your scale has one button,
weights can be stored for one user. If your scale has two buttons (User and
Save/Recall buttons), weights can be stored for multiple users.
2. Tap center of scale platform with foot and wait until "00.0" appears.
3. Stand on the platform without shifting or moving until weight is displayed.
4. For single user scale: When weight reading appears on screen, step off the
scale, press Save/Recall button and hold for about 2 seconds to save the
reading.
For multiple user scale: When weight reading appears on screen, step off the
scale, and press User button to select a user number. Then press Save/Recall
button for 2 seconds to save the reading.
5. Weight reading blinks twice, then becomes stable. A small number (1-5)
appears in the upper right hand corner of your display, indicating which of the
5 weights is displayed. (Once you have 5 weights in memory the current weight
always saves as "1" and the oldest reading is eliminated.)
6. Weight reading is saved. Press Save/Recall button to review the last 5 weights or
let the scale shut down automatically. (Note: until you have 5 weights stored in
memory, the display will show the number and "–" for each weight for which
no data point has been stored yet; i.e. "3 –", "4 –", "5 –" if only 2 weights
have been saved.)
Hope this helps!!
Open Questions:
Top Mitsubishi Televison & Video Experts
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
