Grinder blocked
if
you hear it trying to grind, but is not, or hear it spinning and is not
grinding, more than likely it is blocked, or so oily that bean will not
drop. Coffee beans, have so much oils in them, that after a while it
gets caked up, and beans either get jammed, or stuck. If you hear
grinder low humming, then it is probably stuck or clogged, if it is on
but hear like a spinning sound, beans are not dropping, because they are
stuck because of oil build up. If you can get to the grinder, turn
machine off, unplug, get all beans out, if turning up side down to do
so, get clean dry terry cloth,and start wiping and cleaning, when you
feel your done, spray a LITTLE, no much pam in there, refill and try
again. As said early if it is a low humming, like motor turning but
jammed, do not use until jam is fixed, you will burn up motor, then have
more expensive fix. Let me know if this helped and solved problem. Mr
Bean Man from Fixya
