Question about LG CU400 Cellular Phone
Emergency Download/LG My phone says emergency download and can't be used what should I do ?
Posted by MissSaint on
  • 5 more comments
  • Anonymous Dec 24, 2007
    I also got a screen that said emergency download. I turned the phone off and it will not turn back on
  • Ki_chan Jun 08, 2008
    My phone says Emergency download, and it won't do anything. It won't even turn off.
  • Saxman838 Jun 19, 2008
    I have An LG Shine Cu720 Referb...And it's been perfect up until now...I turned it off, then turned it back on the next day, and the Emergency Download screen poped up...What is the solution?
  • Anonymous Jul 01, 2008
    yeah i turned mine off like you said and now it wont turn back on no loinger how long i hold the red key
  • Anonymous Jul 02, 2008
    I had the same problem. Had to take the battery out to turn it off. The red button would not work. Powered up when I replaced the battery and pressed the on button.
  • Anonymous Mar 22, 2009
    I have the same problem and i can't connect it to the pc . . .please help us :'(
  • Anonymous May 01, 2009
    i flash lg 260 when i finesh the phone is plinken
Anonymous
Take the battery out, plug it into the charger, then put the battery in when it tells you to, then wait until it says charge complete.
Posted on May 15, 2009
Anonymous
Take the battry off, and put it back in, ten hold the red button en put your charger in, then it will turn on, just let your phone load till the battery is full. and you can use normal
Posted on Dec 06, 2008
Anonymous
    New Friend:
Take the battry off, and plug in from your wall charger in, the phone will show ATT and will advise to install battery, just let your phone load till the battery is full. and you can use as normal
Posted on Mar 06, 2010
Anonymous
Take the battery out then put it back in... all fixed
Posted on Jul 04, 2008
Anonymous
Just switch off and back on again i have the same prob
Posted on Jan 04, 2008
4 Related Answers
Anonymous
  • 79 Answers
SOURCE: after water damage worked for a month now says emergency download
you have probably oxidized system board of phone, put it to service, they should clean it
Posted on Jul 11, 2009
Anonymous
SOURCE: Emergency Download/LG
remove battery and sim card ,connect phone to charger then replace battery and sim card ,phone will say please wait then begin to charge once charge turn on phone. Make sure phone is dry inside and out
Posted on Oct 09, 2008
Anonymous
  • 12 Answers
SOURCE: my LG vu wont stop say emergency download
have you dropped it in water\
Posted on Aug 02, 2009
Anonymous
SOURCE: LG PHONE STUCK ON EMERGENCY DOWNLOAD
i HAD THE SAME PROBLEM SO AS POSTED BY PREVIOUS MEMBERS, I TOOK OUT THE BATTERY AND SIM CARD. I THEM USED A BLOW DRYER INSTEAD OF PUTTING IN THE SUN AND BLOW DRIED INSIDE THE PHONE, THE SIM AND BATTERY. ONCE I PUT THEM BACK IN I IMMEDIATLY PUT IN ON THE CHARGER AND THE EMERGENCY NOTICE WENT AWAY. IT MAY HELP TO NOTE THAT I HAD DROPPED IT IN SOME WATER WHICH IS WHAT MAY HAVE TRIGGERED IT. THE BLOW DRYER TOOK ALL THE MOISTER OUT FROM INSIDE INCASE I COULDNT SEE ALL THAT WAS WET. GOODLUCK!
Posted on Oct 02, 2009
Emergency Download
Keep taking the battery out and plugging in the charger and unplugging it...Eventually the phone will restart by itself.
Oct 31, 2009 | LG Vu CU920 Cellular Phone
Drop Phone In Water
you need to get the phone flashed. you need to have the bios flashed. you can do that using the cables that came with the phone and software from the manufacturer's site.
Oct 15, 2009 | Cell Phones
I turn on my phone it goes to a screen saying Emergency Download
Wait does it say emergency mode only? If so this has happened to me many times on this phone.
Turn off the phone and remove the battery. In there will be you should see the SIM card. Pull out the SIM and put it back in. Put back the battery and turn on your phone.
For some reason on these phones the SIM card gets dislodged. When it does the phone won't work because the SIM card is what makes the phone your number etc. All cell phones, that have no service otherwise will be able to call 911. Apparently it is a law, so that is why your phone is on emergency mode. Without the SIM card the phone is a phone without service and will therefore only work in emergency mode.
I hope this is what you meant.
Aug 13, 2009 | LG Vu CU920 Cellular Phone
After water damage worked for a month now says emergency download
Jul 11, 2009 | LG CHOCOLATE VX8500 Cellular Phone
I'm stuck on the yellow screen thats says "refreshing"
This could be a software or a hardware fault. If you recently changed the firmware or made other modifications to the file-system using EFS Explorer (or similar software), it may well be software related.
If you think the problem may be software related, try using Emergency Download mode to reflash your phone.
Possible faults to check with the hardware include:
  • The battery is empty, damaged or worn out. Try taking the battery out and connection your phone using the USB cable only.
  • The contacts of the battery are damaged or the battery has leaked.
  • The screen may be damaged and will not display a picture - check if the lower buttons light up when the End Call (Red) key is pressed.
In the case of a hardware fault or if you are unsure, contact the store from where your purchased your phone on for advice on the best action to take.
Emergency Download Mode __________________________________________ What is Emergency Download Mode? Emergency Download Mode allows you to connect your phone to your computer and use flashing tools (e.g. LGDMP) to restore or change your firmware.
_________________________________________________________
How do I access Emergency Download Mode?
  1. Make sure your phone is off.
  2. Hold down the Green (Call) + C (Delete) + Red (End Call) + Image Stabiliser (Lock) buttons
  3. Your phone should turn on and go straight to a screen saying 'Emergency Download' without first showing the usual LG Logo.
  4. You can now connect your phone using the USB cable and use Flashing tools to fix your phone.
_____________________________________________________________
Use the EFS explorer mode and check the maps.
If there is a map named TOTO and a map LGAPP.
First rename the map LGAPP in to any name you want or change
it like this AAAA.
Secend Rename the map TOTO to LGAPP.
Delete the first map you renamed the LGAPP.
When your finished choose disconnect and wait until the process is done.
You will see the phone starts up in a normal mode if not then
you've to reflash the phone.
I hope this will helps.
May 25, 2009 | LG KU990 Viewty
Emergency download
  1. put out aku
  2. wait till dispear the "Emergency download"
  3. than put in aku
  4. new  open it
Feb 16, 2009 | LG KU990 Viewty
Emergency download message on LG U830
Problem fixed! Press and hold 5 key and power on key together. Remove the battery, then replace and try again. I had to do this a couple of times before it worked, but now everything seems ok.
Feb 27, 2008 | LG CHOCOLATE VX8500 Cellular Phone
mine does too i took battery out then back in it worked but now it syas that again. charge it up
LG CU400 Cellular Phone Logo
11,512 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
Rusum Gupta
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
