SOURCE: Tom Tom won't charge
double check the connection. I had this with a one xl and it turned out to be a small bit of debris that had gotten into the car charger and stuck there so that even the home charger would not help.
I used a compressed air can for computers to blow it out..
also get a magnifying glass and check the connector strips inside the connector.
If you see damage it will probably have to got in for repair
if this info was of use then please click
SOURCE: tom tom was working in the car while driving. The tom tom stopped
There is a small hole on the tomtom device base. Inside it there is a reset button.
Press it and turn device on.
Try to turn it on while connected to the electricity, if it is a battery problem it should work
If it doesn't work I suggest you to bring it to a tomtom support center.
