Refrigerators Logo
A
Anonymous Posted on Jan 25, 2014
Light not working
How do I replace the light globe?
Jayesh Panchal
Level 2:
Sergeant:
Champion:
  • Sharp Expert 280 Answers
  • Posted on Mar 03, 2015
Jayesh Panchal
Sharp Expert
Level 2:
Sergeant:
Champion:
Answers
280
Questions
0
Helped
124882
Points
621
Model No required if two door you can open Glass of Lamp after that open two nut and replaced with same one.
The light in my Kelvinator fridge will no longer work, can it be fixed, globe has been replaced , also
Barbara: You can remove the globe and replace the light bulb with an appliance light bulb. If it still doesn't work, try wriggling the socket a little bit with the light bulb in place (so you don't get shocked). If it STILL does not work, yes, a socket can be replaced and rewiring can be done.
Headlights wont work on 1998 mustang v6 Running lights brake lights and gauge lights work fine. The lights only trn on when i hold the high beam switch. Any suggestions?
check fuses and check globes . Globes might have two filaments and low beam ones has blown . Had this globe thing happen on two globes at the same time on Ford Falcon's Halogon globe headlights.
Brake light and license plate lights won't work
All lights rely on a good connection between the globe base and the metal body of the car.
This is the cause of your problem.
You'll probably find rust in the globe holder stopping the globe from making a good connection.
You may have to replace the globe holders, but it will be worth trying to clean the rust back to bright steel.
Replace park bulb.vt commodore
To replace the front parklight globe on a vt commodore can be a little tricky.
1.turn the lights on to see which 1 is inoperative once you know turn lights off.
2.open bonnet
3.go to side that is inoperative and on the back of the headlight you will see a round large plastic cover turn this to release it.
4.under the headlight globe there will be 2 wires flow these to the park globe socket gently twist and pull it out.
5.once the sockets out and you can see the globe ,pull the globe out of socket.
6.push new globe into socket
7.refit the socket in headlight
8.refit all trims
9.turn lights on make sure new globe is work..
No taillights park or dash lights
check park/tail fuse regarding dash ,park ,tail problem .brake light on passenger side is probably the brake globe needs replacing .Turn signals on passenger side could be globes or switch,check globes first ,if globes and fuse are ok ,may well be the switch especially if park switch and turn signals are on the same switch lever/stalk
Rapid blinker oldsmobile alero 2004
It sounds like one or more of the light globes is not working. The easiest way to check them is to turn on hazard switch and then make sure all are working. If any need replacing ensure the correct wattage globes are used. If after replacing globes and some are still not working, It could be a bad earth connection in the light fitting. First, check how well the metal base of the globe fits into the socket. If it is a bit loose remove the globe, squeeze the sides of the metal socket with some pliers so that the globe fits snugly in the socket. If it is still not working correctly, check the earth wire that runs from the globe socket and any connectors in the wiring loom near the Light Assemblies as well as where the earth wire is attached to the body. If necessary, remove, clean thoroughly by removing any corrosion or paint and re-attach securely.
2helpful
Can't find light globe in MC924JLA LG Microwave
I think you're referring to the bulb which is not working. You have to remove the cover from the microwave to gain access to the bulb. Replacements can usually be found at appliance repair shops or stores and electrical or lighting supply stores.
My break light works but my tail light does not work what could be the issue?
The brake and tail light globe are two different filiments in the one globe. One can blow but the other one can still work, I suggest that you replace the globe.
Light Globes
You have 12 volt globes that are 50 watts power. Check out a home improvement store/lighting store for a replacement.
Replacement of Light globe in Ice Dispenser
USE LESS THAN 5W GLOBE IF AVAILABLE
OR
7 W IS A STANDARD GLOBE BEING NORMALLY USED, WILL & SHOULD NOT AFFECT THE POWER CIRCUIT AS PER MY EXPERIENCE
BEST WISHES
Top Sharp Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
