General Electric WBVH5200J Front Load Washer Logo
A
Anonymous Posted on Jan 19, 2018
Burnt resistors on mother board
Wires broke off the thermistor, drain pump hasn't worked since. Looking at the mother board there are two burnt resistors by the Jack where the terminator plugs in. Also, when I go into test mode it will not go past test 1. Do I have to replace the board at this point or can I replace the resistors?
Eric Taylor
Level 3:
Master:
  • Master 590 Answers
  • Posted on Jan 20, 2018
Eric Taylor
Master
Level 3:
Master:
Answers
590
Questions
6
Helped
206144
Points
1556
The fact is that no manufacturer will give you part nos ion safety and legal reasons the only way is to go to a scap yard and y=try to find the same scrap machine for the circuit board, the value of the resistors is irrelevant as they burnt out for a reason that replacement resistors wont fix eric
4helpful
Ge side by side frig won't defrost gss25sgmb new heater motherboard thermostats
Replace the thermistors #4 and #5 . 4 is the white bullet looking piece on top of the coils inside the freezer , with 2 white wires . 5 is at the bottom of the freezer , on the left side . These thermistors tell the main board , the temp and the board goes into defrost according to temp the thermistors "tell it " .
Ice freezes into one big chunk, and water leaks out of the door. its not the water dispenser because i turned the water off.
It sounds like the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils ( will have to remove the inside rear freezer panel , 4 screws ) , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature
7helpful
2answers
GE model #GSS201EMBWW is not defrosting, checked defrost heater and it was burned out. Replaced with new 2 heater design and now it burns all the time, which is most likely what burnt the other 1 out....
This is how the defrost works . I have NEVER found a defrost problem associated with a bad main control board since these computerized GE's came out in 2000 . Lots of thermistor problems , lying to the board , causing different problems .
Your GSS model refrig does not have a defrost timer . It works off of the main control board . Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
1helpful
2answers
Where is the defrost timer locate
The timer is the main control board behind the refrig , behind the 8X10 panel . If you have a defrost problem , Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
I have never found a control board causing a defrost problem .
2helpful
My GE Adora freezer section constantly gets down to -5 to -9 degrees, when the setting is 0.
I would advise replaceing # 4 AND # 5 thermistor . The # 4 , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils ( remove the inside rear freezer panel ) , with 2 white wires going to it . Part number WR55X10025 for both . The # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
The ice melts and drips into the freezer.
You will need to remove the food from the freezer , enough to be able to remove the rear freezer panel . The # 4 thermistor is probably bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off .
3helpful
2answers
GE refrigerator, ice melts in ice bin
Since your refrig is cooling , I would replace the # 4 AND # 5 thermistors . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
It will not defrost..the mother board ,the defrost thermostat,and the heater have all been changed..
Sounds like the # 4 and # 5 freezer thermistors need changed . The # 4 , is the 1 " torpedo looking piece , clipped to the top of the coils . The # 5 thermistor , is located at the bottom of the freezer section at the bottom of the rear panel , with 2 white wires going to it . Still a 1 " torpedo looking piece . The # 4 , tells the main control board , the evaporator temperature . The # 5 , tells the board , the freezer temperature .
Burnt out power board
I sympathize with your problem, but I think you are knocking at the wrong door. You should contact your local Packard Bell dealer.
Hope it helps
Part number: 316809100002-R02
I too have the same power board burnt out ... did anyone ever find the part you was looking for ... Thanks
Top General Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
How-2-Repair.com
How-2-Repair.com
Are you a General Washing Machine Expert? Answer questions, earn points and help others
