Question about Pelican Cobra TT Racing (6770936FA)
Pelican Cobra TT Racing wheel xbox 360
I don't know how to plug it up, there's an odd cable.
1 Related Answer
Anonymous
SOURCE: need a pc converter adapter for a pelican cobra tt racing wheel
amazon ps2 to a ps3 converter
Posted on Aug 22, 2010
Turntables
I think your SOL dude as those types went out a long time ago and were proprietary.
Apr 18, 2014 | Audio Players & Recorders
1986 Toyota Corolla GT-S started miss firing on the freeway
Look 1986 what you can get $200.00 for it.I try head gasket fix for $ 35.00 works fine for last two years.
May 01, 2013 | 1986 Toyota Corolla 2 Door
I have a seagate goflex 1tb external drive. The drive is not recognized by the usb 3.0 adapter unless I only use the very short seagate cable that came with the goflex. I need the extra length but off the...
I have the exact same drive. If off-the-shelf cables are not working (which is odd) I would suggest buying a USB 3.0 extender. This will extend it about 3 feet. You can purchase them for <$5 online! Let me know if this helped out any.
Jul 08, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Hello. I was cleaning the dust out of my computer fans and somehow the little blue & white, and red & white cables came out of where the attach to the motherboard. I am looking for a diagram so...
Looking at the board with the SATA connectors to the right and the backplate to the left. Look to the lower right corner of the board. You will see a group of two rows of pins(9pins with one missing) The pin that is missing is pin#10. The pins are numbered even on the pin#10 side, odd on the other. The Power Switch - Pin 2 is the Red wire/white is Pin 4. The Power Led - Pin 6 is blue pin 8 is white.
Shhhh! Must be a Gateway Secret.
Jun 13, 2011 | Gateway GM5664 Desktop PC
Hi i have mitsubishi pinin 4x4 2.0 GDI engine, when starting on a warm engine it often has a 5 sec missfire then goes ,cold start no probs , its had full service mits main dealer only recently had new...
Some vehicles don't run well with the platinum plugs. It will cause the engine to misfire and skip. I would go back with the OEM or a step above unless your car came with platinum plugs which is doubtful. The plugs may be firing off correct when cold but as the engine warms and more friction is there the plugs may be doing more bad because it's not firing correct from the plug being warm. It sounds strange but I work for BOSCH and there are alot of things that don't seem normal to someone that's not involved in making these parts and seeing the everyday test and use. Good Luck. Let me know what you find out and what works.
Apr 14, 2011 | Mitsubishi Passenger Cars & Trucks
Sometimes it works and other times it doesn't - very unpredictable and most annoying
You have a loose wiring connection either at the plug, in the cable or at the switch. The most likely place is where the cable gets strained, at the plug or where it goes into the body of the cleaner. The switch could be faulty. Plug in switch on and move wiring near plug does it start? yes? then plug out check plug if you can or cut wire 2" from plug annd put new plug on.
If no leave it switched on Then try same near where cable goes in. If it stats get someone to remake connection into switch.
If no switch on and odd without touching cable. Does it start? if yes switch needs replacing.If no report back.
Jan 12, 2011 | Vacuums
How do you plug up the toy john deer tractor ? both ends doesnt fit
Hi Marsha,
You have a cable running from the battery to the motor. That cable has a connector that must be disconnected by squeezing the sides of the connector. Now take the cable end from the charger and connect it to the connector that is connected to the battery. I know they look a little odd, but they will match up...and only one way.
Thanks for using Fixya.
Dec 23, 2010 | Peg Perego John Deere Turf Tractor
Get video but not audio.. may have cables connected improperly??
It's either cables not connected correctly, or the TV that you are connecting it to is muted or the audio source isn't correct (for example running thru an external audio system). Try connecting it to another TV in the house and if it works, then you'll know if it is or if it's not the DVD player itself. Also try a different audio cable. If it's RCA plugs (typically, the older style with Yellow, Red, and White colors on the connections), it's odd for them to fail, but not sure the connections you have.
Nov 04, 2010 | Toshiba SD-3980 DVD Player
What router do I use for the hp officejet 6110 All-in-one
You should put both computers under the same "groupwork" name .
to change this settings right click on MY COMPUTER the go to properties
then the go under the COMPUTER NAME tab. CHANGE the settings Look at PICTURE #1
When you choose the "workgroup" name make sure that you pick a unique name.youll probably want to use your name.look at picture #2.after changes are done your asked to restart once you have done this FIRST part let me know i can help you with the setup of the Nwetwork Printer.b07620b.jpgbdecea2.jpg
Nov 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Cable to DVD came loose. Odd Connector
take note on the cables twist style just follow its twist.
Sep 16, 2007 | HP Pavilion s7310n (EN996AA) PC Desktop
Pelican Cobra TT Racing (6770936FA) Logo
70 people viewed this question
Top Pelican Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Pelican Video Game Console and Game Expert? Answer questions, earn points and help others
