Question about Samsung TXN3071WHF 30" TV
No Power... Hi i have the TXN3071WHF and after about 3 months of no activity i decided to turn on the tv one afternoon, only to find that the tv would not power on.  The red standby light is not illuminated either, it's like there is no power getting to the tv.  I have tried several different outlets in my house to no avail.  There has not been any physical damage to the tv and it was plugged into an undamaged surge protector.
Anonymous
  • 93 Answers
Did u check the fuse in the set. if so check the power supply section
Posted on Oct 24, 2007
For whatever reason the TV no longer turns on. We finished watching a dvd and shut it off. Came back to turn it on and no lights or anything. I've unplugged it and plugged it back in and when i'm behind...
i can't say' its easy.please check the wire connections,,,re solder the circuit board if needed...if the status is still repairable ,troubleshoot the power supply section..........
Aug 27, 2010 | Samsung TXN3071WHF 30" TV
Tv turns on but has no picture
there might be a high voltage leak from the plyback.Open the back cover of your tv .turn it on and observe which part of the plyback has a leak..use a silicon adhesives to cure the leak..cover it heavy and complete..
tnx please rate my help.
Jun 04, 2010 | Samsung TXN3071WHF 30" TV
Philips 42" lcd tv when turn on no picture is coming up, has been working fine but now decides does not want to
Sir replace you PSU power supply unit as I said in chat, you TV is 12 years old and now its 3 months old all of the sudden? I am refering to the chat script.. Then when your told that yes even a 3 month Tv can experince these issues due to spikes, power problems Etc you take off give me a thanks for trying rating... Sir you asked for my advice and sir take it to a repair shop and there going to tell you the same thing I did but I saved you bucks telling you it here... Do the right thing..I gave you my email if you have any further questions sir..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 22, 2009 | Televison & Video
Samsung TXN3071WHF Problem
When the set is on, the red light should be off, not on...
Apr 07, 2008 | Samsung TXN3071WHF 30" TV
Powers on but turns it self off after 15 seconds.
CHECK FLYBACK TRANSFORMER LEADS FOR BAD SOLDER JOINTS, HAVE REPAIRED SEVERAL WITH SAME PROBLEM.
Dec 02, 2007 | Samsung TXN3071WHF 30" TV
POOR PICTURE
i have the exact same problem. mine has a yellow tint to it. im
Nov 25, 2007 | Samsung TXN3071WHF 30" TV
Xbox 360 screen cut off on left side
Ok, I've had the same issue and I was able to fix my problem. I was getting cut off sides in HD mode on my playstation.
I entered the service menu by doing this:
Turn TV Off
Use remote and hit "Mute 1 8 2 Power" (not at the same time, but one after the other)
The TV will come on with the service menu. Enter the 1080i adjustment screen. Write down ALL the values in case you mess up. Adjust the values as necessary to fit your screen. It's sort of like adjusting a computer monitor's image for different resolutions.
Hit me if this helps... mlager at sysnosis dot com
Sep 20, 2007 | Samsung TXN3071WHF 30" TV
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Vertical black bar in the middle of the screen
GREEETING FROM bELIZE YOUR SET NEEDS TO BE TAKEN TO A QUALIFIED TECH IT IS HAVING A VERTICAL PROBLEM OR A PROBLEM IN THE POWER SUPP PROBABLY A FILTER IN THE POWER SUPPLY.GOOD LUCK.
Oct 27, 2006 | Samsung TXN3071WHF 30" TV
Open Questions:
See all Samsung TXN3071WHF 30" TV Questions
Samsung TXN3071WHF 30" TV Logo
110 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
