Beeping Noise When i try to do anything with the register it works fine and then all of a sudden starts making a beeping noise and continues and doesnt stop until i unplug the machine or do a program reset. I have not tried oding a master reset and do not want to unless absolutly necesasry. Please help.
Make sure oven is plugged into a grounded outlet, and that the outlet is actually grounded. Although extremely rare, I have seen ovens where insects were walking on the back side of a control panel, and causing problems. Could also just be some sort of electronic failure.
hi, that's sounds like the freewheel lever is engaged, please make sure it out of freewheel mode, now remove the rear axle then refit, does it still make that noise ?
Yes, okay now check the connection from the rear axle to the frame, make sure they are clean and a good connection, Regards www.gewizrepairs.co.uk
Do you see anything on the monitor screen? Does the tower make any beeping noise or clicking noise, or does the fan tries to start up when you power the computer on? Are the cables connected properly?
If you see anything on the monitor screen, or if you hear a beeping sound, let us know so we can diagnose further.
Sound like high voltage splitter ( born or defected ) Am sure this is your problem. Or maybe fly back defected. Check for possible loose connections. Thank you !!
