SOURCE: DVD-LS5
had same problem here but then i found a soloution might help you helped me
I purchased my LS50 over 16 months ago. I had a H03 error before and it went away after sitting on the shelf for three days. It worked ok for another couple of months and then stopped again. The screen says reading but the motor is not spinning. , then i spotted that the laser lens is in the wrong place. When at resting location, the lens should be parked near to the spindle in the middle. The mechanism to move the lens backward and forward sometime get stuck at the end of its travel - furthest away from the spindle. If your player is out of warranty, then you maybe able to try this. Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Forgot to mention. You can also clean the gear shaft in case there are small particules stuck to the grease and affect the movement. After cleaning, apply a tiny bit of grease just to lubricate the moving shaft. Not too much. I am glad that the instructions help.
it helped plenty of friends hope it helps you
SOURCE: PANASONIC DMR-ES30V KEEPS SWITCHING OFF
I had this code (f09) on my Panasonic DVD VHS recorder. After seeing that it meant overload I took the cover off to look for burnt out components. I found that an electrolytic capacitor had bulged (look up capacitor plague on wikipedia). I replaced the capacitor with one of a similar value from an old power supply and it worked fine.
SOURCE: VCR DVD Combi DMR-ES3OV
SOURCE: Error code U61 on a
The manual refers to the U61 as being a recovery mode. Have you left it at U61 for a period of time while it tries to recover?
U61 ≥There was a power failure or the AC plug was disconnected while the unit was on. The unit is
carrying out its recovery process. This process restores the unit to normal operation. The unit is not
broken. Wait until the message disappears.
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
SOURCE: Panasonic DMR EZ27 displays 'Guide' and freezes
There's a newer firmware version (1.13), that's available from Panasonic rather than by download. Check out this forum thread
