Question about Canon PowerShot A75 Digital Camera
Sony-dsc-w15 memmory card
When  we  removed  memmory  card  from  camera  and  put  it in laptop  to  transfer the photos, then  we  put the m.card back to camera, the camera  is  making  bip  bip  sound  cotinuous and  are not able to capture  pictures.
Suggest some solution and oblige.
Nikunj
[email protected]
Posted by articlinic on
Adolph Smith
  • 137 Answers
Virus on your card. Load virus program . Scan card ,kill virus and put it back to Camera.
Posted on Dec 24, 2007
Photo transfer from camera to LAPTOP
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Jun 08, 2014 | Samsung PL 70 SL720 Digital Camera
Transfer photos camera laptop
Hi Taylor Buckley,
I will be glad to help you. Request you to try following the below steps which might help:
    (1)Connect a USB data cable from camera to laptop which helps in transferring.
    (2)Remove the memory card from the camera and put in in the memory card slot (if the laptop has one) and copy files.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Dec 26, 2013 | Dell Computers & Internet
I shot some photos with no memory card installed, i can view the photos on the camera when the card is not in the camera but i can't upload to my computer, is this possible??
You have two options. If you normally transfer your photos by connecting your camera to your computer, remove the memory card before making the connection. This will allow the computer to see the photos in the camera's internal memory.
If you normally transfer your photos by putting the memory card into a card reader, use the Backup command in the Settings-1 menu to transfer the photos from the camera's internal memory to the memory card, then transfer the photos from the card to the computer as normal. See page 48 of this manual: http://www.olympusamerica.com/files/oima_cckb/TG-610_TG-310_Instruction_Manual_EN.pdf
Aug 31, 2013 | Olympus TOUGH TG-310 Digital Camera
My camera is fine and I transfer photos to my desk op . Now I also have a laptop which I want to transfer photos on to but can't find soft ware to do so.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy selected pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 31, 2013 | Canon PowerShot SX10 IS Digital Camera
I want to downlode potos from laptop on sd card if posible herd can be don can u help please
Hello there.
You can download (transfer) photos from laptop to sd card directly only. Put SD card in your laptop and transfer it (copy from laptop/paste to SD card). Check if your SD card is unlocked (check lock button on it). Probably, it is impossible to transfer it from laptop to digital camera, but describe your photo camera. Even if you transfer it to SD card, photo camera will not see them.
Please rate if this was helpfull.
Sincerely,
Steve TM
May 28, 2011 | Cameras
I have a sonny ericson mobile w395 and i would like to upload photos to my laptop, i have a usb cable attached but nothing happerning. what am i missing?
TRANSFER ALL PICTURES TO MEMMORY CARD AND THEN PUT MEMMORY CARD IN A MEMMORY CARD READER AND THEN INSERT THE MEMMORY CARD READER (WHICH HAS MEMMORY CARD INSERTED IN)TO THE LAPTOP
Sep 24, 2010 | Ericsson Cell Phones
Transfering photos back to memory card
Hi, Welcome to FixYa.
You can do it through your laptop's card reader or using a card reader device.
Take your memory card out from the camera and put it in the
adapter(a card holder) given to you. Now you can use it in Laptops
in built-in card reader/ card reader device.
If the SD memory card is read only this will not work, otherwise
this way you can copy photos to Card very easily. Also you can copy
photos from memory card in the same way
Our site need your feed back for improvement.
If the post helped you please select 'YES' here
Jul 09, 2009 | Kodak EasyShare C340 Digital Camera
Not Formating Olympus Xd Picture Card H 512MB
very strange indeed better take the camera and the xd card to your supplier and see what is wrong .. i gues you have not pushed the card the wrong way?? or put the little white tab downwards ( than it is locked against accidentaly formatting )
it's the only thing i can come up with or remove the xd card put a few photo's on internal memmory than connect cam to pc > upload the pictures > then set the jog dial to setup > reset the camera and try again ,
Jan 19, 2008 | Olympus FE-180 Digital Camera
Missing Pictures
You may have chosen the delete from camera option. When you transfered the photos.
Have a closer look at the options when you download the next lot of photos, some times there is a tick box for delete while transfering.
Nov 28, 2007 | Olympus Stylus 700 / 700 Digital Camera
Canon PowerShot A75 Digital Camera Logo
52 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
