Washer stopped during rinse/spin cycle. Will not drain in any switch position, but it will spin. If you try to run the washer, water slowly leaks out onto the floor during the spin. Thanks!
Sep 27, 2014 | Washing Machines
Aug 30, 2017 | Whirlpool Washing Machines
Jun 08, 2011 | Roper RAS8445KQ Top Load Washer
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
Possible Causes/Procedure
• If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent,
• This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Feb 17, 2010 | Roper RTW4300SQ Top Load Washer
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jun 30, 2009 | Roper RAS8445KQ Top Load Washer
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Jan 05, 2008 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQO will not drain or spin on any setting. Please let me know if there is an easy fix.It sounds like the knob/timer just ticks, but nothing happens. I have so many clothes that need to be washed. PLEASE HELP!!!
mine leaks on bottom in front. we turned it at a 45o angle and looked under. it seems to be leaking behind the pump., it is a metal thing. dont know what it is or how to fix it. it is 3 yrs old, for the two of us, unemployed. not used that much. I am looking for instructions/manual so we can do it ourselves. (no hose leaks)
wont spin on spin cycle or spins slowly
roper washer lid will not lock in spin cycle
major banging during the spin cycle
Washer not spinning
