Boston Acoustics BA745 Computer Speakers Logo
Khadijah Evans Posted on Jan 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
JUST PLUGGED BOSTON BA745 INTO OTHER LAPTOPS AND AUTOMATICALLY WORKED. BUT NOT ON THIS GATEWAY WINDOWS 7. I HAVE PLUGGED DELL DESKTOP AND OTHER SPEAKERS TO THIS GATEWAY AND WORKED WITH NO PROBLEM. DON'T UNDERSTAND WHAT THE PROBLEMS IS! PLEASE HELP ME!!!!!! :-)
adam adms
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 829 Answers
  • Posted on Jan 25, 2014
adam adms
Master
Level 3:
Renaissance:
Answers
829
Questions
0
Helped
70043
Points
2193
1 - out of account
2 - Clean all device
3 - Scan Anti Virus
4 - promising device driver
5 - open a new browser site
Testimonial: "It most certainly, has given me a few more ideas. But i went to restore earlier and turned off anitvirus like suggested but still said that needed to be turn it off. I don't understand what opening a new browser site has to do with it unless maybe chrome, firefox or explorer maynot work. I have been fulling with this mess for the past 2 or 3 days!!! :-( What is out of account???"
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on May 28, 2010
SOURCE: How do I plug my BA745 Boston speakers into a MAC
I have the same speakers. It should have two plugs, one green and one pink. the pink plug is for a microphone. On the side of the speaker with the control knobs, you will find a headphone jack and a microphone jack. Unless you plan to plug a microphone into the pink microphone jack on the side of the speaker, you don't need to plug in the pink plug that goes to the PC. This is basically a microphone extension cord that runs through the speaker cord. That's all the pink plug is for. The green plug, on the other hand, is for your audio out. take the green plug and plug it into your computer's head phone outlet and you're good to go. You can use the speakers with any device that has a headphone jack. Just make sure you use the green plug, not the pink plug.
Anonymous
  • 1073 Answers
  • Posted on Dec 11, 2008
SOURCE: Will these speakers work with a Mac laptop?
If there are a plug to connect them on your Mac i cant see why they shouldent work. Just connect them to the audio-out plug on your Mac
Good luck to you
Anonymous
  • Posted on Jan 05, 2009
SOURCE: will my boston accoustics ba735 speakers work with a dell laptop?
We also have a Gateway Computer purchased in 2001 with the Boston Digitanl BA735 speakers. We ran into a similar problem when we upgraded from Windows ME to Windows XP, with no sound after the upgrade. After consulting with computer stores and "Geek Squad", it was finally determined that Windows XP set the speakers for analog not digital. Once that was reset, our sound returned. Hope this works for you.
Mollys Mom
Hook up to a receiver
what kind of connector is opn the sub? probably a mini-audio plug like a set of headphones? If that is the case, you can get an adapter from mini-plug to rca cable.
I reinstaled my computer its a Gateway with windows 7 to factory settings and now my subwofer is not getting any sound. The other speakers work fine, I checked all the volume controls, cords power. the...
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality then apply
hope this helps W7
How do i connect the boston BA745 comp. speakers to my gateway desktop?
Assuming you have the BA745 2.1 speaker set up, all of the cables connect to the subwoofer and then to the computer or the satellite speakers (these are built into the speakers IIRC). Take the cable with the black box (2 pins) to red and green. The red and green plugs go into the matching color ports on the computer and the pins on the black end fit into the jacks between the those for the two satellites. Plug the single end speaker cable into the subwoofer port all the way to the right on the back of the subwoofer. Plug the wire with the two plugs into the matching color jacks (blue to the left, red to the right). Then plug in the power adapter cable in the farthest left jack and plug in the other end to a surge protected power strip (that is plugged in and turned on).
Sound system connected to new system with Windows 7, yet no sound appears - Dell Inspiron system
Go To:
Start Menu:
Control Panel - Classic view (if needed)
Sounds Icon
Here you can adjust and assign (enable) these speakers. You may need to upgrade your sound card to support them, but should not need to.
I just reformatted my harddrive and I am now loading my programs back on and I just noticed that I have no sound on my compurer from my BA745 speakers How do I reinstall the driver/s for these Boston...
I don't believe it is the speakers.
You need to reload the drivers for the sound card, then your speakers should work.
What brand and model computer do you have?
If it is a gateway, go to gateway.com, then drivers, then enter your tag number and all your drivers for your machine will appear. It's the same for all the other brands as well.
I have a Boston BA745 sys where can I download a
you should'nt need a driver for the speakers, you just plug it in the sound port, unless you dont have a sound card driver, let me know weather you need a sound card driver , cheers
My computer doesn't recognize my Boston BA745 speakers!
look at
http://supcontent.gateway.com/support.gateway.com/s/SOUND/speakers/7003709/700370935.jpg
if its like that it should work. if it does not, test the sound out plugin for audio with some headphones... check that your master volume is un muted. check that plugins are inserted properly, if still no audio, click "start" right click "my computer" click "properties" click device manager"
and look at your audio area,,, if its all fine, no red or yellow little things beside your speakers.. your fine...
otherwise.. its probably a bad wire leading from computer to sub..
I have no sound
Yes you must have the correct drivers installed. If you formatted your drive, you will most probably have to download all motherboard drivers also
Will my boston accoustics ba735 speakers work with a dell laptop?
Mollys Mom
2answers
check where its plug in the back check your volume make sure its not on mute
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
