Photos not printing proper colors and after cleaning printhead about 10 times and doing calibrations it still shows the gray color is missing.
Not much to go on. If you mean the black cartridge is not giving any ink, and the printer does not say the cartridge is empty you still have a problem. But it is possible to solve.
If I'm guessing right, remove the cartridge with the black ink and look in the printhead. You see the little pipe sticking up, where the black ink is going in. with a dropper, just do a few drops of cleaning fluid on that pipe and replace the cartridge. Than let the printer print some black pages, till the black ink is coming through.
It also could be the cartridge with the black ink is empty or dried. If you shake (take care you will spray ink if you don't seal the ink outlet) and you don't hear any ink in the cartridge, unless what the computer or printer thinks it still is empty.
SOURCE: How do I calibrate my monitor?
In order to get out to the printer what your camera captured three things must be calibrated (profiled). First of all your camera must be profiled to descibe to the other elements what is the color space., Next the monitor must be profiled, and all of the Adobe, and other free programs that tell you it can calibrate your monitor will not do the job. You have to invest in one of the packages out there that will do it ACCURATELY. Finally, and maybe most important, is that your printer must be profiled for every type of paper and resolution setting. Once you achieve this, you will get accurate prints out of your 890 (I have it also). I suggest you look up several programs which will give you more detail on the Color Profiling Issue....Try Qimage, Monaco EZColor2, and Profile Prism (New ...to create a profile for your camera).
SOURCE: Canon A540 or SD card problem
Hi Rich, This sounds like a problem with filing system of the memory card and is indicative of forthcoming bigger problems. Try remove from the camera and slip into a memory card reader attached to a PC. You have to try and recover as much photos as you can. Thereafter, it may be required to format the memory card either via PC or the format command in the set-up/menu of the camera. Further you can use diagnostic utilities (PC side) to determine if the memory has developed any bad areas. Hope this be of help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
SOURCE: Cant print date on Image
you can only print dates on photos when your camera is set on post "card" (compact) mode...try it
SOURCE: Canon powerShot SD900
Let me know all above you said is in live view and if playback of previously taken pictures is good then its problem of defective CCD Imager Sensor in your camera Canon S400
Canon has announced free of cost repair on such problem for selected models and your camera model is in list.
For details click Canon CCD Advisory.
Regards,
SOURCE: blue skies are splotchy
I had the same problem, when i check from repair people, they say that the CCD needs cleaning. I havent tried it yet, But going to do it soon. Will see what happens
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Thanks, Joe
