Olympus FE4020 Digital Camera Logo
A
Anonymous Posted on Jan 25, 2014
New battery won't charge - Olympus FE4020 Digital Camera
1helpful
2answers
How to tell if a105-s4074 satellite battery is bad
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
1helpful
My device won't charge
This situation sometimes occurs when the batteries get overcharged. Use the phone for a day and then attempt to charge. If it still won't charge, remove the battery for about a minute. Then re-install the battery and attempt to charge. If that doesn't clear the problem, you may need to get a new battery.
I reinstalled XP on IBM T41, now battery won't charge. Could this be Driver Problem
Sounds like you need a new battery.
It's not just a battery in a case, it also has a small circuit board inside to control the charging etc, if that's faulty it won't charge, or if it has dead cells in it won't charge.
3helpful
2answers
Uniden battery will not charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
4helpful
3answers
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
2answers
Sony vaio vgn-nr285E battery won't hold a charge
3answers
Why its battery quickly drains
3helpful
2answers
Nokia 5130c-2 always charging but when i remove charger battery is low give me solution
Hello.
these symptoms means that a new battery is required.
the phone's battery is exhausted after a long time of use, replace the battery and the problem is solved.
Best Regards.
1990 Plymouth colt, new alternator, still won't charge. What tells alternator to charge battery?
Have you also had the battery checked? If the battery is bad, then it won't charge. All of the terminals need to be checked for corrosion. All wires must be secured properly. Check to see if the ground cable is properly attached to the frame of the vehicle.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
