Windows will not start up. Gives me windows start up option, but doesn't find a solution
I was logging on to my MSI S6000, between the blue log on page and the home screen, it went gray. So, I manually shut it down. Now wen I turn it on it goes to start windows normal or windows start up solutions. Neither will work, the solutions option just takes hours, then tells me it has found nothing wrong.
rayjor
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Press and hold down the Delete key, power on, and this will start the BIOS setup, where you can choose the device to boot from. Usually a hard drive.
Posted on Dec 26, 2017
5 Related Answers
Danny Nagdev
  • 47 Answers
SOURCE: Start > turn off computer does not work on XP
Some process running in the background is not letting the system shut down. Use task manager to kill unnecessary processes before pressing turn off. If it shut downs then try to locate the process using taskmanager which is causing this problem.
Let me know if it helps.
Posted on Apr 13, 2008
Anonymous
  • 37 Answers
SOURCE: Wont let me log in
I think the blue screen you are reffering to is the blue screen of death. This happens when a serious failure occurs. Your OS's system files may have got corrupted and that would be the reason for this. Try reinstalling Windows.
If the problem persists, get your Ram memory checked by a technician.
Posted on May 13, 2008
Anonymous
  • 9 Answers
SOURCE: start up problem
Start up the computer when the computer boots up go into settings in the Bios (black screen) change the boot settings to boot from cd/DVD put windows disk in reboot you will be asked to boot from CD push Enter.
This will load up windows after while you will come to a screen Enter for Install or R for repair push R for repair this will take you to the DOS prompt it will check keyboard don't touch anything.
next it will ask you repair 1. windows put a 1 in push enter. Then will ask you for admin password just push enter the repair should start. when finshed take disc out reboot. Hope this makes sense? if that fails let me know there is another solution
Regards,
Spud
Posted on Jun 18, 2008
tonybudz
Tony Budz
  • 162 Answers
SOURCE: when I boot up the screen is all colors and lines
It sounds to me like your cable is loose to the lcd or the video card is not properly 100 percent seeded into the mother board. Prolly the cable in one way or the other, perhaps bad cable.
Posted on Nov 22, 2008
Anonymous
  • 123 Answers
SOURCE: Start up problem!!
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Posted on Apr 26, 2009
When I log in on facebook I don't get our home page-- get anorher page that I logged on before
Log out of the other account by clicking the down-pointing triangle in the upper-right then clicking "Log Out."
Aug 01, 2014 | Facebook Social Network
How can I exit my friend's facebook account and log in to my account?
In the upper left hand corner of any page on Facebook you will see a dark blue arrow that is pointing down, click on it and a drop down menu will appear. The log out option will be in that menu.
good luck and thanks for using fixya.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jul 02, 2014 | Facebook Social Network
Msi s6000 was working but cut off and will not power up
Disconnect Ac adapter, remove the battery, Plug back in Ac adapter and try to turn on. If that works shut down from menu, then replace battery and start up again.
Apr 03, 2012 | MSI S6000017US PC Notebook
Webcam is there one on the msi s6000
According to the specs online it appears it does have a 1.3mp webcam.
Here's the specs:
http://netbooklists.com/multimedia-entertainment-notebook-msi-s6000017us/
I hope this helps.
Regards
Mar 03, 2011 | MSI S6000017US Laptop
Computer shut down before logged off. now a blue
If it's blue screen with a lot of writing , that means hard disk failure is immenent , so backup your data and take it to the service .!
Jan 20, 2010 | Dell Dimension 3100 PC Desktop
Blue screen on start up and no response
go in bios and disable the on boot password and if tha blue screen appear again write down the error that is writen on that page and search on the net for it.
Nov 28, 2009 | HP Elitebook 8530w Mobile Notebook
The password page coming up
Review your user accounts, you may need to clean the registry. I reccomend CCleaner it;s open source and its pretty solid and best of all it's free
Nov 23, 2009 | Gateway 450ROG Notebook
My laptop won't shut down properly!
Is it possible that you have changed the settings of what buttons do what on your system? E.g. you could have changed the power button to "switch user" instead of "shut down", to check this (in XP) go to "Power Options" (in Control Panel" and then click on the "Advanced tab" at the top, then select "Shut down" from the drop down menu at the bottom of the window.
If this is already set to shut down then maybe you could do a system restore in case another setting has been changed, restore it to before the PC started doing this.
Alternatively try actually choosing "Turn off Computer" from the Log On screen (press Ctrl + L to get to this screen, or choose switch user/log off). If you are using Vista I beleive that there is a shut-down option from the Log In Page there (which again you can access by pressing Ctrl + L on the keyboard.
Hope this helps!
Dec 29, 2008 | Computers & Internet
When I boot up the screen is all colors and lines
Nov 21, 2008 | Toshiba Satellite A215-S7422 Notebook
Computers & Internet Logo
24 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
