Hi
I have a 1991 toyota corolla gti, the car starts fine but then the rev counter goes to max(9000 rpm!) and the car cuts out. if you try again it does the same thing. it starts everytime but then cuts out. its not the idle valve as the car over revs not under revs. any help will be greatly appreciated.
thanks
http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
Engine cuts out at 3000 RPM?http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
High rpm in neutral? Inconsistant high RPM in neutral?http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Jetski Sputters and Low RPM? http://whatisbyme.blogspot.in/2012/07/jetski-sputters-and-low-rpm.html
Fuel Injection Problem And RPM suddenly increaseshttp://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000?http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills?http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
1995 Toyota LS: Misfire at idle or low RPMhttp://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM?http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
hi,
yes i do mean 9000 rpm! the gti starts redlining at 7500 rpm and maxs out at 9000rpm!
when i start it it starts for a second, the revs go up to 2500 rpm then all of a sudden they shoot upto 9000rpm and the car cuts out. this whole process takes about 2 secs max. if you try to restart it will restart but then will do the same thing and cut out. any help will be much appreciated thanks.
hi,
its a 4age engine. ignition module, is this the one mounted just below the windscreen on the passenger side? i disconnected it and it wouldn't start(makes sense!), but isn't this just used to start the car? it starts fine its just after it starts thats when the problem begins.
do you really mean 9000 rpm or maybe 900. please clarify what you mean be over rev and under rev.
