Mould on inside ring
SOURCE: Simpson washing machine not turning on
check outlet with multimeter for 120 volts .If voltage found check cord for 120 volts .If cord has 120 volts turn on timer jumper lid switch . did this help?
SOURCE: Maytag front loader washing machine. Mould
I had the same problem with my Neptune washer until I ran a cycle with straight vinegar and water. This helped get rid of the mold. I have to run a "vinegar" cycle about every 10 cycles. I would try cleaning the seal with vinegar first and let it air dry. Neptune washers need to air dry after every cycle.
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Testimonial: "thanks for the tip"
SOURCE: Simpson front loader washing machine repair person
I have Simpson EZI sensor 9.5kg and during the washing i have a EF message coming up.
