Hello, check to see if you are getting 24 volts to the solenoid valve, if you are and the solenoid does to click to let the water in it must be replaced. If you are not getting 24 volts start at the transformer and work your way toward the solenoid valve to find where the voltage stops.
Sorry to read about your problem, I hope this helps you out.
you must have a defective water inlet valve, and its letting water in, just a little.. it maybe dirt in the valve, clogging it.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
you need to be using only genuine AA parts if you are the feed tube or try may be cracked AA sells an annual maitenance kit on thier site for about 60 bucks go to www.aprilaire.com
