Cameras Logo
A
Anonymous Posted on Jan 24, 2014
Canon p5d calculator
Replace battery
Canon HS-1200TS Compact Desktop Calculator. It stopped working.
Question edited for a lot more clarity.
Question moved from Canon Camera to correct one.
Replace the internal battery
https://www.google.com/search?q=canon+hs-1200ts+change+battery
The calculator is frozen (no keys will work) A number 4 shows on the screen and a "C" prints out
Try removing the batteries and unplugging from power supply. Then replace batteries/reconnect. That may restart the unit.
How do I replace canon hs-1200ts calculator battery
Take out the three small screws on the top of the back of the calculator then pry the two halves apart. You will find the small "button batteries fastened to the board. You need to bend up the small tab, remove the batteries and replace with similar battteries.
1helpful
How to replace battery in Canon WS-1400H calculator
The battery is an LR1130 and is probably under a small hatch on the back. Do you have a photo of the rear of the calculator?
Where to purchase batteries in NYC or online?
you need to open the calc and take out the battery then go to
Radio Shack they have the replacment
hope it will help
18helpful
How do you change the battery in a Cannon LS-100TS Calculator? The pamphlet states, "do not attempt".... I would think it would be easy.
Undo 3 screws on the back. The rest of the case clips together along the outside edges, wriggle and pull the two halves apart (gently). Battery is easily visible and accessible. LR44, replace with + upwards. When you have reassembled the case you might need to press the reset button (on the back, small black dot, use a pen or similar to push it) before the calculator functions again.
1helpful
How do you change the battery in a Canon LS-100TS calculator
Here is the owner manual for your calculator as a free download. http://www.devicemanuals.com/guide/Calculator/Canon/Canon-Portable-Display-LS-100TS-User-Guide-TkRFeE5UQT.html
just download it and save it to solve your current issue and for future reference. J.
7helpful
Canon dk100i battery change
it's very easy you have to unscreww on the back of the calculator the 2 small screws and then remove the top and be carefull not to unplug the small wires. Inside you will see the battery holder and you will need to remove the battery carefully by pushing from the side of it with something vry small (like a dime) and then replace it by a new battery type CR2016. Then you put back the cover and the screws.
After that you will have to do a reset with a small pin or with the tip of a pen.
Then it will work as a new one.
I just did it yesterday and itis working pretty well.
Good luck
Regis from Montreal, QC Canada
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
