The most common reasons an INFINITI I35 heater isn't working are a broken heater blower motor, a problem with the thermostat, or a failed heater blower motor resistor.
two things to look at - is it a blue ray disc?or a self recorded? if self recorded- is it in a format your player can read?- and if it was a $ discount disc- might have wrong country code for your player
Model No Required below Model No AH-X18MEV Self diagnosis mode given
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
• If the power cord is unplugged or the circuit breaker is turned off, the self-diagnosis memory is lost.
AUX
Operation lamp(red)
Timer lamp(orange)
Super jet lamp(green)
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
Remark
THE TEMPERATURE BLEND DOOR STUCK OR BLEND DOOR ACTUATOR MOTOR FAULTY,YOU NEED TO DO A EATC DIAGNOSTIC TEST TO GET FAULT CODE SEE WHY YOU ARE NOT GETTING HEAT.TO DO A DIAGNOSTIC TEST FIRST WARM ENGINE UNTIL IT GET 120 DEGREES.WITH ENGINE OFF IGNITION SWITCH ON SIMULTANEOUSLY PRESS OFF AND FLOOR BUTTON THEN WITHIN 2 SECONDS PRESS AUTOMATIC BUTTON SELF TEST TAKE UP 20 SECONDS INDICATING BY BLANK DISPLAY WINDOW ON THE EATC MODULE. IF DISPLAY IS BLANK FOR MORE THAN 20 SECONDS OR IF CODE 888 IS DISPLAYED GO TO EATC SYSTEM TEST UNDER TESTING IF NO CODES ARE DISPLAYED AND SYSTEM IS NOT OPERATING PROPERLY GO TO SYMPTOM DIAGNOSIS IF CODES DISPLAY RECORD CODES. BEFORE TURNING IGNITION OFF EXIT SELF DIAGNOSTIC.BY PRESSING DEFROST BUTTON EXIT THE SELF DIAGNOSTIC PRESS BLUE BUTTON. IF ALL FAIL LET A GARAGE CHECK IT OUT.BUT ALSO CHECK COOLANT SYSTEM IF COOLANT SYSTEM VERY LOW YOU HAVE NO HEAT PROBLEMS.
when problem occur while cam is operating, the self-diagnosis function starts working, and may display the service mode display code. in your case, C:31:40, pertains to a part of the cam tape compartment mechanism called the drum that doesn't start up. issues could prevent you from recording, playing back tapes, rewinding or fas forwarding. t/s steps are: try diff tapes esp. w/prev recordings, reset cam (press reset button while cam is on, located just below the menu button, in the panel where the lcd screen goes to), power reset (remove batt and ac adapter and leave cam w/ any power source for at least a minute). if issue persists, unit will require repair. hope this helps.tnx:)
A bizarre coincidence but our Sony DVD player DAV C700 did exactly the same when the kids were watching a DVD. All other functions on the system are still working but the DVD player wll not eject or play - and the self diagnosis function C 81 remains illuminated on the display.
what does c31.23 mean when showing on the screen.can i fix the problem myself or do i have to get a professional to fix it.when i try to use the video a beeping noise and the above number is displayed on screen
