Question about Sharp MX-2700N Color Copier
Reset code vk for SHARP MX-M283N - Sharp MX-2700N Color Copier
2 Related Answers
Anonymous
  • 95 Answers
SOURCE: sharp mx-2300N printer error maintenance required
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Posted on Jan 15, 2010
lilgto64
Matt Wolanski
  • 3 Answers
SOURCE: Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Posted on Oct 11, 2012
How do i reset the mx-M283N?
try opening and closing all covers that you can find. If you aggressively removed a misfeed you might have damaged a sensor that registers jams, and it might need to be replaced.
Copier Collin Houston TX Copier and Imaging Expert
Jul 04, 2014 | Sharp Office Equipment & Supplies
We are getting a VK maintenance code on our MX-M850 copier. Does anyone know what it is and how to fix it?
This is one of the scheduled maintenance codes. it comes on at a certain "milage" and requires a technician to reset it.
If you're in Houston we'd be happy to help you out, and supply new machines should you need any.
Skelton Business Equipment Houston Copiers
Jun 19, 2014 | Sharp MX-2700N Color Copier
Sharp MX4100 maintenance code vk
Check out this little walkthrough I have put together. Adjusting the printer port settings on your computer should take care of it. Sharp Printer Offline Solution
Feb 20, 2014 | Sharp "MX-4100N Copier, Printer, Scanner...
A line across the page when printing and coping
try to look for some foreign objects on the scanner area.. a dirt stock on the scanner glass if it has adf and a dirt on the mirror if it soes not have an adf.
Feb 13, 2014 | Sharp MX-M283N Copier
Creates a line when coping and printing on the pages
vertical line or a repetitive horizontal line? Please describe in fullest detail what yo're getting.
MX-M283N has error H5-01
Do not turn off and on after executing simulation.just press CA
Jan 30, 2014 | Sharp Office Equipment & Supplies
Sharp m453n e7-11
This is the white ref strip under the glass.
It may be dirty, dirty optics or dirty lamp or lamp may need to be changed
Feb 05, 2013 | Sharp Toner for MX-M283N, MX-M363N/U,...
Sharp mx-2300N printer error maintenance required code vk
Dec 23, 2009 | Sharp MX-2300N Color Copier
Feb 04, 2009 | Sharp MX-2700N Color Copier
Sharp MX-2700N Color Copier Logo
594 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
