Question about Arcsoft ShowBiz® DVD 2 Full Version for PC
Can't save to DVD
ArcSoft ShowBiz DVD2. I can only get a message saying 'an error occurred while creating your new DVD. However a backup of your project was saved in the Showbiz temporary folder'. I then can't write to DVD from the temporary folder. I would like to copy video to DVD directly, has anyone else had this problem? nonnadi0
Posted by dianereynold on
2 Related Answers
Muzahura Frank
  • 2069 Answers
SOURCE: I get "Failed to write
well this may not neccessarirly be a Arcsoft ShowBiz DVD. but Your problem may be that the system is running out of "temp" storage on hard disk. You may be running into the 4G file size limit of a FAT32 formatted hard disc on these temporary files, and that is preventing Showbiz from completing its rendering process. It is best to have a large hard disc and formatted to NTSF specifications when dealing with the very large files video work requires.
Regards
Posted on Dec 01, 2010
E Pranshu
  • 55 Answers
SOURCE: Cannot copy my video pictures
if it is not supportable first convert the video to the format that it is accepted
Posted on Dec 24, 2010
When I try to capture a video using my ClimaxDigital VCAP303 device, I get a message come up on Arcsoft Showbiz 3.5 saying - "The device is not available or being used by another application. Please...
Sometimes a program is still working even if you have closed the task window. You can finish the task tree in task management panel or simply restart your computer. BTW, ArcSoft ShowBiz has a new version 5.0. Its functions are much more powerful than any versions ever.
Sep 25, 2011 | Arcsoft ShowBiz DVD 2 (3265)
Hello, I have a problem with the arcsoft showbiz
You said you transfer a VHS to DVD, so does it mean you get videos from analog camcorders to make a DVD? For those camcorders, you need special line to connect with computer and your computer also need analog video capture card. If you mean your videos on DVD discs have troubles, maybe you should know what is your disc type. Rewritable ones are OK to be edited with ShowBiz, and once-only ones are not, they should be fanalized in DVD camcorder first. If it's the program's problem, go to www.arcsoft.com to ask their proffessionals. There's a new ShowBiz 5 you can have a try.
Aug 24, 2011 | Arcsoft ShowBiz® DVD 2 Full Version for PC
I have showbiz dvd2 and am trying to convert vhs to dvd. The process is straight forward however, while the audio is fine, the video is jumpy, not a smooth flowing picture. I have changed bit rates etc but...
we don't have a fix for this although i'm sure it will be along the same lines.
Contact Arcsoft direct.
The quick fix is to use other software to capture and then import the video into Arcsoft to edit, burn to DVD etc.
Debut capture software. It is free and good.
http://www.nchsoftware.com/capture/index.html
Scroll down to near the bottom and download the "lite" version.
when you open, click on "device" at the top to open the capture window.
and try to watch this link for a short tuturial on showbiz 2 movie making...
http://www.youtube.com/watch?v=cnBLwv2aRD4&feature=related
Jun 05, 2011 | Arcsoft ShowBiz DVD 2 (3265)
Keep getting "an error occurred while creating
You will obviously get your answer if you contact ArcSoft's support.
You also haven't provided enough information for someone to be able to actually help you.
Mar 18, 2011 | Arcsoft ShowBiz DVD 2 (3265)
I'm trying to create a dvd in Arcsoft Showbiz. When I add an AVI file, it is reading it as a sound file, so no video shows, only sound plays. I've never had this problem before and have burnt many other...
I think you should use Leawo DVD Creator. Leawo DVD Creator is an easy and fast DVD creator for any video to DVD creation. It can create DVD from popular formats like AVI, MPEG, WMV, MP4, FLV, RM, MOV, XviD, 3GP, etc., apply DVD menu from various stylish presets in customized background and music.
And the trouble you meet will never appear in this software. You can use it easy.
Feb 27, 2011 | Arcsoft ShowBiz DVD 2 (3265)
Cannot copy my video pictures on a file in Arcsoft Showbiz DVD2
Dec 23, 2010 | Arcsoft ShowBiz DVD 2 (3265)
Wew
The problem with all the Arc soft Showbiz usually occurs and they had come with the new patches, that must be installed to solve the issue..
You can download all the patches from the following link,
http://www.arcsoft.com/downloads/showbiz2/arcsoft/showbizdvd_2.2.2.53_2.2.2.69_update_e.exe
http://www.arcsoft.com/downloads/showbiz2/arcsoft/showbizdvd_2.2.2.69_2.2.2.81_update_e.exe
http://www.arcsoft.com/downloads/showbiz2/arcsoft/showbizdvd_2.2.2.81_2.2.2.107_update_all.exe
After insallting, your issue should be solved
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Dec 03, 2010 | Arcsoft ShowBiz DVD 2 (3265)
I have no clue how get my Jazz Elite HDV178 camera/camcorder to work as a web cam. can someone please eplain it to me??? thank you.
Make sure the software that came with the camera is intalled. Conect the camera to your computer (via USB the (batteries are not required to be in the camera when you do this)) press the button above the USB. On a pc in the bottom right corner will say "installing new device" ... load up "Showbiz DVD 2" (Start, all programs, Arcsoft showbiz dvd2, showbiz DVD 2.) select “capture from device”. It will show a live image off the camera. If you want to use the camera on an instant messaging service (I use windows live messenger 8.5) close Showbiz. Open instant messenger. Once loaded select Menu, tools, webcam settings. There you can adust settings like the brightness. Then if you want others to know that you have a web cam click on your display name, options, personal. At the bottom of this tam there is a tick box makes sure that this is ticked. Hope this helps
Dec 26, 2008 | Jazz DV-179 Digital Camera
Capturing analog video from 8MM tape and saving it on PC
Try Cyberlink Power Producer and set it do capture via DV cable.
Nov 30, 2008 | Canon ZR850 Mini DV Digital Camcorder
Arcsoft ShowBiz® DVD 2 Full Version for PC Logo
119 people viewed this question
Top Arcsoft Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you an Arcsoft Computer and Internet Expert? Answer questions, earn points and help others
