Question about Sharp MX-2700N Color Copier
SHARP MX-M283N DK code - Sharp MX-2700N Color Copier
1 Related Answer
Sreelal Devadas
  • 66 Answers
SOURCE: what does code DK indicate
IT MEANS YOUR BLACK DRUM AND DEVELOPER NEEDS REPLACEMENT, IF NO PROPBLEMS ARE THERE IN YOUR CPY QUALITY YOU CAN RESET THIS BY PRESSING #*c* BUTTON RESPECTIVELY WITH NOT MUCH TIME DELAY IN BETWEEN THE KEYS, THEN MACHINE WILL ASK FOR MAIN CODE THEN PRESS 2 AND 4 THEN PRESS START THEN YOU CAN SEE THE DRUM AND DEVELOPER COUNTER RESET SELECT THAT BLACK DRUM AND PRESS OK THEN DELOPER ALSO LIKE THIS THIS WILL RESOLVE YOUR PROBLEM, IF ANY QUERIES FEEL FREE TO CONTACT AND VOTE AND RATE THIS AFTER GETTING YOUR PROBLEM RESOLVED.
Posted on Jun 13, 2011
Sharp MX-3100; what does DK mean
h r u . DK MEANS black drum life is over need to replace black drum unit or Reset black drum unit counter.
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code07
Then you can select what you want to clear so the bk drum unit
Feb 26, 2015 | SHARP MX-3100N
How do i reset the mx-M283N?
try opening and closing all covers that you can find. If you aggressively removed a misfeed you might have damaged a sensor that registers jams, and it might need to be replaced.
Copier Collin Houston TX Copier and Imaging Expert
Jul 04, 2014 | Sharp Office Equipment & Supplies
Sharp mx- 3100n error codes dk
black image unit need to be replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 03, 2014 | Sharp MX-3501N All-In-One Printer
A line across the page when printing and coping
try to look for some foreign objects on the scanner area.. a dirt stock on the scanner glass if it has adf and a dirt on the mirror if it soes not have an adf.
Feb 13, 2014 | Sharp MX-M283N Copier
Creates a line when coping and printing on the pages
vertical line or a repetitive horizontal line? Please describe in fullest detail what yo're getting.
MX-M283N has error H5-01
Do not turn off and on after executing simulation.just press CA
Jan 30, 2014 | Sharp Office Equipment & Supplies
Sharp m453n e7-11
This is the white ref strip under the glass.
It may be dirty, dirty optics or dirty lamp or lamp may need to be changed
Feb 05, 2013 | Sharp Toner for MX-M283N, MX-M363N/U,...
The Sharp MX2700 Colour machine has come up with an error code DK, what does this code refer to.?
This code means the Black Developer powder has reached the end of its life A service call will be needed to replace this for good black prints
Apr 26, 2010 | Sharp MX-2700N Color Copier
Getting maintenance code DK...What is it referring to?
DK refers to the counter for the black developer powder.... a service call will be needed for this
Feb 17, 2010 | Sharp MX-2300N Color Copier
Sharp MX-2700N Color Copier Logo
212 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
