Question about Yamaha Rx-v465/rxv465 Home Theater Receiver
Problem with Yamaha RX-V673, HDMI OUT NOT WORKING
Posted by ERICK JIMENEZ on
5 Related Answers
dewan nafees ahmed
  • 1894 Answers
SOURCE: Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
Posted on May 22, 2008
Anonymous
  • 8546 Answers
SOURCE: Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Posted on Apr 27, 2009
Marek Podmaka
  • 127 Answers
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Posted on Mar 02, 2010
Anonymous
  • 8546 Answers
SOURCE: Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Posted on Apr 30, 2010
Anonymous
  • 857 Answers
SOURCE: My Yamaha rx v465 has
Check the settings on your source device, it may be set to send audio as PCM over HDMI, you need to set the audio output on the source device to bitstream or raw.
Note if you are using the original PS3 you need to leave it on PCM as it can not bitstream the HD audio from Blu-ray(the new PS3 slim can do this).
Also Check your PC is really output 5.1 or 7.1 via hdmi.
Posted on Sep 07, 2010
1helpful
My RX- V673 Yamaha receiver won't turn on. I have power and the stand by switch is on
Try holding the 'tone control' and 'info' buttons and press power. This will unlock it if it is protect mode. If it turns back off right away, then you most likely have a problem in the amp circuit which needs to be repaired.
How to connect my JBL JRX 115 speaker to my Yamaha RX V673 receiver
You would use a standard banana plug to either a 1/4 phono or speakon plug. The JBL JRX 115 has both on the back. All the outputs on the Yamaha RX V673 have banana plugs. The channel you plug into would be up to you, there are many choices and they are listed on the back of the unit.
I connected the HDMI 1 input from my tv to the HDMI output on the Yamaha Rx-v673 but i do not get any signal going throught to the tv. when i try put my samsung input source as HDMI 1 the tv prompts me...
To connect a TV you should use the Rx-V773, not the 673.
With the 673 you can use TV only as input, not output.
However there is a firmware update for your receiver. Try it.
1helpful
Yamaha Receivers have International Warranty?
Just send an E-Mail to Yamaha's customer service section. I'm certain they will be able to tell you.
The only other problem you might encounter is if the USA model uses a different mains system to the one in Brazil.
1helpful
My Blu-Ray DVD player is connected to the AV Receiver with HDMI cable.
You're not going to get any difference using an optical cable. In fact, your receiver cannot look at both jacks at once anyway. If you select an input, it only looks at one jack, it cannot take info from both.
Yamaha RX V673 airplay problem
Disable IGMP filter on your router
Open Questions:
See all Yamaha Rx-v465/rxv465 Home Theater Receiver Questions
Yamaha Rx-v465/rxv465 Home Theater Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Muzahura Frank
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
