White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
v
vanessa lindley Posted on Jan 24, 2014
Creations 3 is sewing in reverse reverse button not lit
rtark
Level 1:
New Friend:
  • Contributor 37 Answers
  • Posted on Jan 26, 2014
rtark
Contributor
Level 1:
New Friend:
Answers
37
Questions
0
Helped
6605
Points
47
All serging machines run in reverse, the hand wheel turns reverse compared to regular straight stitch machines which run counter clock wise. I need more information, My email is [email protected].
Why is my 7700 only stitching backwards
Follow the instructions below if the machine is stuck on reverse
1. Turn the machine off.
2. The reverse button may be stuck in the reverse position.
- Press and release the button to see if it releases and allows the machine to sew in the forward direction.
3. Check that you have selected the correct stitch.
Some stitches will sew in reverse and some will sew reinforcement stitches.
4. Make sure you are holding down the button while sewing 3-5 stitches.
If you do not hold the button down while sewing reinforcement stitches, the needle will sew in the same place.
5. Remove bobbin and clean the bobbin area. Reinstall bobbin.
6. Turn the machine off and hold the reverse button for 3-5 seconds.
7. Turn the machine back on and test to see if the machine will sew forward.
If the problem persists, Contact Customer Support
I HAVE A MODEL 6234 SINGER SEWING MACHINE THAT ONLY GOES IN REVERSE HOW CAN I SOLVE THIS PROBLEM
Your reverse button is stuck. Try this before going to a professional. Unplug your power coed. 1) Place the stitch width to it's widest. 2) Remove the top cover. 3) Spray a little penetrating oil (wd40) behind the reverse button. 4) Start pushing the reverse button until it freely move. Might need a long flat head screwdriver to push the reverse button from the inside out.
Empisal creations and episal EXP889 sewing machines.... which is the better one and more recent model
It really depends on what You envision yourself doing with the sewing machine and then finding the machine that has the most functions that fit your needs.
Empisal 889:
  • 36 Stitch functions
  • Front load bobbin
  • On/off switch
  • Left and middle needle position
  • 18 Stitches
  • 4 Step buttonhole
  • Stitch width control
  • 4.5mm Maximum stitch width
  • Soft cover
  • 4.5mm Maximum stitch length
  • Reverse stitch
  • Twin needle
  • Free arm
  • Carrying handle
  • Uncoupling bobbin winder
  • Clip on, clip off foot
  • Drop feed
  • Sews on buttons
  • Zipper foot
Empisal Expression 889 Sewing Machine Empisal Sewing Machines
Empisal Creations
  • 4 Step buttonhole
  • 19 Built-in stitch patterns
  • Oscillating hook
  • Sews on zips
  • Adjustable stitch length: 0 - 4mm
  • Adjustable zigzag stitch width: 0 - 5mm
  • On / Off swithch
  • Free Arn
  • Accessories
  • Reverse stitching
  • Horizontal spool holder
  • Self uncoupling bobbin winder
  • Cover on accessory compartment
  • Large working surface
  • Thread cutter
  • Adjustable presserfoot pressure
  • Built-in tension
  • Darning plate
  • Fold away carry handle
  • One touch snap on foot
  • Versatile utility stitches
  • Sews through heavy fabrics
  • LED lighting
Empisal Creations Sewing Machine Empisal Sewing Machines
https://www.russells.co.za/empisal-creations-sewing-machine
Why will it not sew forward,but will sew backward?
Check to make sure your reverse button is lit up. If it is press it.
Will not sew in reverse when reverse button pushed
my kenmore 385.17526 will not go in reverse when I push ...
www.shopyourway.com > Manage My Life > Questions
my kenmore 385.17526 will not go in reverse when I push the button ... Having asewing machine that doesn't reverse can be a bit disappointing, especially ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home_and_Garden/.../Sewing.../index.html
Sewing Machine Won't Sew in Reverse. My Elna 3007 became temperamental atsewing in reverse some years ago. On occasion, I will need to push the button ...
Bernina 1230 Reverse Button Fix ' Temecula Valley Sewing ...
https://tv-sewingcenter.com/bernina/bernina-1230-reverse-button-fix
Aug 30, 2010 - The reverse button of the 1230 had been pulled or popped out of ... All I had to do to fix the button was to hold the button in, and then push the cap forward. ... My 1120 Bernina reverse button will not work and the person who ...
Why is my creations 3 sewing in reverse when the revrrse button is not lit
Push and hold the reverse button for 7 seconds and see if that fixes it.
Machine won't go into reverse
What model machine are we talking about here? If it is a Designer 1, Reverse doesn't show up on the screen. You need to hit the Reverse button twice in succession, the button stays lit up, and the machine should sew in reverse until you hit Reverse again or change stitch.
When a reverse arrow shows on the screen, it is usually when a programmable stitch is selected and you need to hit Reverse to complete the programmed task.
Get back with more detail on your machine and the problem, and maybe I can offer some more specific help.
Pamsquilt
2helpful
Reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
2helpful
3answers
Sewing backwards
The reverse button works by hitting it twice in succession to make it stay on (it lights up), and you turn it off my hitting it once again. If you just want to reverse for a little bit, you hold it down while you sew, then let go. Is the button lit all the time?
Having said that, it sounds like Nannayoyo needs to take her machine to a service centre - the electronics behind the button panel might need replacing. Is it possible the button is stuck in? Maybe phone a Husqvarna service person - not a sales person - and ask for advice.
Everyone - are your machines new? If yes, you need to go back to the sales centre straight away and get it fixed or replaced while you wait. If these are problems that have just appeared when your machine used to work perfectly, probably the best solution is to take it for a service. It might just be a speck of dust has settled on the electronics behind the panel and is causing unpredictable behaviour.
Top White Sewing Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
