Question about Sharp MX-2700N Color Copier
Scan to usb
How to scan to USB
Using my Dimage Scan Dual 4 SW with Windows 7 gives me trouble. Have konica Minolta SW ver. 1.0.0 for windows XP. It works fine on the XP computer. But I have great difficulties loading the SW on
Have you right clicked on the .exe file of windows 7 executable for the Minolta scanner to select compatibility to switch it back to xp.Have you tried to use third party twain drivers for scan software such as silverfast or vuescan instead?
Jan 24, 2015 | Konica Minolta Dimage Scan Dual IV Film...
Hello and help. a have a new(ish) computer running 7 and have borrowed a minolta dimage scan dual III. i was able to install the software with the converter program, but it won't recognize the scanner....
; sonyscanners.inf -- Sony (Konica Minolta) Film Drivers
; Beta driver for Windows Vista and Windows 7 operating
; systems for all known Sony film scanners.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=2/19/2011,3.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB and SCSI scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
"Minolta QuickScan 35" = SCSIScanner,SCSI\ScannerMINOLTA_#2880___________
"Minolta Scan Dual" = SCSIScanner,SCSI\ScannerMINOLTA_#2882___________
"Minolta Scan Multi" = SCSIScanner,SCSI\ScannerMINOLTA_#2883___________
"Minolta Scan Speed" = SCSIScanner,SCSI\ScannerMINOLTA_#2884___________
"Minolta Scan Elite" = SCSIScanner,SCSI\ScannerMINOLTA_#2885___________
"Minolta Scan Elite 5400 Firewire" = SBP2Scanner,SBP2\MINOLTA&DS_Elite5400&CmdSetId104d8
[Models.ntamd64]
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[SCSIScanner]
Include=sti.inf
Needs=STI.SCSISection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[SCSIScanner.Services]
Include=sti.inf
Needs=STI.SCSISection.Services
[SBP2Scanner]
Include=sti.inf
Needs=STI.SBP2Section
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
[SBP2Scanner.Services]
Include=sti.inf
Needs=STI.SBP2Section.Services
[Strings]
Provider="Sony (Konica Minolta)"
Mfg="Sony (Konica Minolta)"
Apr 04, 2011 | Konica Minolta Dimage Scan Dual IV Film...
Does not work with windows 7; cannot connect to scanner
You have to replace the original Konica Minolta driver with the custom one I have created below. Here are the detailed steps.
1) Install the Konica Minolta XP software in Vista/Win7.
2) Plug in your DImage Scanner into a USB port and turn it on with the door closed. It will detect and install the original Konica Minolta Driver.
3) Create an empty folder on you harddrive (for instance go to my computer, double click on the c: drive, then right click and create a new folder named newminolta).
4) Open windows notepad and copy the following into it:
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
5. Now save you new notepad file in the directory you created as sonyscanners.inf NOT as sonyscanners.inf.txt or sonyscanners.txt (i.e. c:\newminolta\sonyscanners.inf)
6. Go to system control panel (may have to change control panel to classic view to see system).
7. Select Device Manager
8. Select Imaging Devices
9. Right click on Minolta XXXX (depending on model) and click on driver tab. Select Update Driver.
10. Select Browse my computer for driver software.
11. Select Let me pick from a list of device drivers on my computer.
12. Select Have Disk
13. Browse to c:\newminolta\sonyscanners.inf and click OK
14. Click Next. Windows should now say it updated driver.
15. Run Dimage software with door closed. Wait for it to initialize and green light stops blinking.
16. Open door and insert film holder and start scanning.
17. If you are trying to use a Minolta 5400 with firewire in Windows 7, you have to change your 1394 driver to the legacy windows 1394 driver in order for the scanner to detect. Google for instructions as it's too detailed to add in here.
18. The above driver should relink virtually all known Minolta scanners (USB/SCSI/Firewire) to the Windows TWAIN driver so it will work with the legacy Minolta software.
Mar 10, 2011 | Minolta Dimage Scan Elite 5400 Film...
Konica Minolta Dimage scan dual film scanner will not connect to windows 7
It's possible there are no drivers running under W 7 for this remarkable unit and it's a shame .
If you have the W XP install disc , you could install a virtual version of W XP on your HDD .
You could also partition your HDD and install W XP on the new one .
Otherwise ... trashbin . Yes , life is hard .
Regards .
Dec 26, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Minolta Elete Scanner 5400 - Is there a Driver for Widows 7 available
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
Nov 03, 2010 | Minolta Dimage Scan Elite 5400 Film...
Looking for driver for Minolta Scan Elite 5400 (not II) in wndows7
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
Aug 14, 2010 | Minolta Dimage Scan Elite 5400 Film...
Does Kainanderson's solution work with Win7 64bit
Of course it does. I'm using both a Minolta Dimage IV and Minolta Dimage Elite 5400 Mk 1 (firewire and usb). Here's my latest driver:
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
May 13, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Need drivers for Minolta Dimage Scan Dual III to work with Windows 7 64-bits
I used this solution from KainAnderson
1) Install the Konica Minolta XP software in Win 7.
2) Plug in your DImage Scanner into a USB port and turn it on with the door closed. It may detect and install the original Konica Minolta Driver.
; scanners.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Class=Image
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
[Models]
; USB scanners
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
5. Now save you new notepad file in the directory you created as newminolta.inf NOT as newminolta.inf.txt or newminolta.txt (i.e. c:\newminolta\newminolta.inf)
6. Go to control panel (View Devices and Printers).
7. Right click on Minolta Scan Dual III and click on properties.8. Select Hardware tab, then select Properties
9. Select Driver tab, then select update driver
11. Browse to c:\newminolta\newminolta.inf (or wherever you stored file) and click Next
12. Click Next. After running driver file Win 7 should now say it updated driver.
13. Run Dimage software with door closed. Wait for it to initialize and green light stops blinking.
14 Open door and insert film holder and start scanning.
Hopefully I've copied and amended the solution correctly
Feb 10, 2010 | Minolta Dimage Scan Dual III Film Scanner
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Minolta DiMage Scan Dual IV
1) Install all of the usual Minolta software in Vista.
2) Create a new folder somewhere
3) Create a new txt file named minolta.inf and paste this into it:
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
; USB scanners
[Models.ntamd64]
; USB scanners
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
4. Save file. Turn on scanner and go into device manager and update the old minolta driver with this driver. You may have to manually update it.
5. All the normal Minolta programs now work just fine. Enjoy!
Jan 27, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Sharp MX-2700N Color Copier Logo
16 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
