Question about Sony Televison & Video
My Sony Trinitron only turn on when After 5 and up hours..
My sony trinitron KV25DA1 has only sound but no picture appear, but after 5 to 8 hours of warming up it shows the pictures in selected channels and when i try to change channel the picture went of and then the red blinking lights went on and of every 2 blinks. Can i have ifo on this and how to fix it?
Posted by gogooh81 on
City View TV & Computer, Inc.
    Master:
  • Sony Master
  • 450 Answers
1. Your TV has a weak picture tube, the beam current detection circuit muted the video, you may rejuvenate the CRT, or turn up screen control (located on the fly back transformer) a little it may help.
2. Other thing is that to check out is there any dry-out electrolytic capacitors in the main power supply circuit.
Posted on Jan 15, 2018
5 Related Answers
Anonymous
SOURCE: Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Posted on May 25, 2008
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: Sony Trinitron approx 8 years old, no picture, no sound...
That blinks and flashing have a diagnostic code;
Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those, which you will see for each of these faults on a diagnosis screen described later in this article.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Intermittent problems? This is a great feature. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
Now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking four times. This would tell you that you have no vertical sweep, which is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault. It's not a sure cure..
IMPORTANT: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter, which returns everything to the factory preset condition.
Hope it may help you;
Regards,
VOTIT
Posted on Jan 31, 2009
Anonymous
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Anonymous
  • 7 Answers
SOURCE: My Sony KV-32HS420 Trinitron Wega TV will turn on
You have what is commonly known as a shutdown problem. It's an overload in one of the internal circuits. It needs to be looked at by a professional tv reapir person.
Posted on Nov 03, 2009
Anonymous
  • 3 Answers
SOURCE: volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Posted on Jan 13, 2010
I have a 32" Sony Wega Flat Screen TV. Currently
Check out this article: http://www.ehow.com/how_8256946_fix-sony-32-trinitron-picture.html
It goes pretty in depth in how to troubleshoot problems with your Trinitron TV. Hope this helps.
Sep 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32HS420 32" TV.....Turns
Sounds like a diode may have burnt up or if your really lucky it might just be the fuse.!!! You might want to get a secound opinion .But if you know what to look for , which is any component on the motherboard that appears as if had caught fire sader it out amd replace with exact same component which can be ubtained at radio shack.GOOD LUCK TOO YOU!!!!!!!!!
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony Trinitron TV now taking around 5 minutes for picture to appear (sound comes on instantly) Is it worth repair or should I cut losses and replace set?
How old is the TV?
Sony Trinitron sounds like it may be from the 1980's?
Some TV engineers can use a piece of equipment to do a "tube boost" but this is sometimes risky and can completely ruin the tube, but it's a risk you would have to take.
If the TV is over 15 years old, and has been used regularly, (like 4 hours every day or more) it seems likely that the tube has reached the end of life.
TV cathode ray tubes are like light bulbs...they do not last forever!
Nov 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron
Take it to an authorised repair agent. Sonys can be very complicated for both amateur and professional alike. I have spent hours on some of them.Most probably a failed voltage regulator though very common for Sonys and expensive.
Oct 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV-32fs120 Does Not Turn On
i have a unvirasal remote how do iget the codes for it
Sep 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
32 inch sony trinitron wega
It will most probably need an overhual of the power supply
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Televison & Video Logo
74 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
