If the height adjustment on your new vacuum is not functioning properly, there could be a problem with the height adjustment mechanism or the vacuum's belt. Here are a few things you can try to fix the problem:
- Make sure that the height adjustment lever is being pressed down all the way. Sometimes the lever can get stuck in the "up" position, which prevents the height adjustment from working.
- Check the height adjustment mechanism to make sure it is not damaged or obstructed. This may involve removing the vacuum's dustbin or base plate to access the mechanism.
- If the height adjustment lever and mechanism are functioning properly, the problem could be with the vacuum's belt. The belt is responsible for driving the height adjustment mechanism, and if it is stretched or damaged, it may not be able to move the mechanism properly. In this case, you may need to replace the belt.
If none of these solutions fix the problem, it's possible that the vacuum's internal hardware is faulty and will need to be repaired or replaced. If you would like a parts list
