Question about Intel D101GGC Motherboard
Driver alc861 - Intel D101GGC Motherboard
Biostar nf61s-m7 motherboard drivers
Please follow the below link to be taken to the official Biostar Drivers Section for your motherboard.
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=199
Thanks and I hope this helps :)
May 12, 2011 | Biostar (NF61SM7-COMB57) Motherboard
I need the audio & vedio driver ddr101
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Mar 01, 2011 | Intel D101GGC Motherboard
Audio driver to ASUS intel socket 775 P5GD1 PRO! where to be found
Go to this link at the Asus website (I'm assuming you're using Win XP)
http://support.asus.com/download/download.aspx?SLanguage=en-us
Select this version: Version 5.10.0.5136
To download from that site select global. This should help you.
Jan 25, 2011 | Computers & Internet
I have a D102GGC2 motherboard with intel pentium 4 processor 524 , LGA775 Pkg 3.06GHz,.So please tell me about related drivers and chipset and how to download from intel site ?
Link for download of drivers etc. is at the bottom. Choose Operating system, etc and what you need (drivers, software, etc.).
I don't know if it will come to you as a hyperlink or not. If not you will have to copy and paste or type in address bar as one long string.
Manufacturer:
Intel
Part Number:
BOXD102GGC2
General
Product Type
Motherboard
Form Factor
Micro ATX
Width
9.8 in
Depth
8.6 in
Compatible Processors
Celeron D ,
Pentium 4 ,
Pentium D
Processor Socket
LGA775 Socket
Multi-Core Support
Dual-Core
Chipset Type
ATI Radeon Xpress 200 / AMD IXP 450
Max Bus Speed
800 MHz
Storage Controller
ATA-133,
Serial ATA-150
Power Connectors
4-pin ATX12V connector,
24-pin main power connector
Processor
Installed Qty (Max Supported)
0 ( 1 )
Memory
Supported RAM Technology
DDR2 SDRAM
RAM Installed ( Max )
0 MB / 2 GB (max)
Supported RAM Speed
PC2-3200,
PC2-4300
RAM Features
Dual channel memory architecture
Video
Graphics Controller
ATI Radeon X300 Shared video memory (UMA)
Audio
Audio Output
Sound card
Audio Codec
Realtek ALC861
Compliant Standards
High Definition Audio
Telecom / Networking
Networking
Network adapter - Realtek RTL8101L - Ethernet,
- Fast Ethernet
Features
BIOS Features
ACPI support,
SMBIOS support,
Rapid BIOS boot
Hardware Monitoring
System voltage,
CPU fan tachometer,
Chassis fan tachometer
Sleep / Wake Up
Mouse wake up,
Keyboard wake up,
Wake on USB port,
Wake on LAN (WOL),
Wake on PCI device,
Suspend to RAM (STR)
Expansion / Connectivity
Expansion Slots Total (Free)
1 Processor - LGA775 Socket,
2 Memory ( 1.8 V ) - DIMM 240-pin,
1 PCI Express x16,
1 PCI Express x1,
2 PCI
Storage Interfaces
Serial ATA-150 - connector(s): 4 x 7pin Serial ATA - 4 device(s),
ATA-133 - connector(s): 2 x 40pin IDC - 4 device(s)
Interfaces
4 x Hi-Speed USB - 4 pin USB Type A,
1 x Parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
1 x Serial - RS-232 - 9 pin D-Sub (DB-9),
1 x Mouse - Generic - 6 pin mini-DIN (PS/2 style),
1 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style),
1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45,
1 x Display / video - VGA - 15 pin HD D-Sub (HD-15),
1 x Storage - Floppy interface - 34 pin IDC,
1 x Audio - Line-in - Mini-phone stereo 3.5 mm,
1 x Audio - Line-out - Mini-phone stereo 3.5 mm,
1 x Microphone - Input - Mini-phone 3.5 mm
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D102GGC2
Hope this helps.
Nov 27, 2010 | Intel D102GGC2 Motherboard
I have a problem with the drivers of my motherboard
Try searching for chipset drivers insted of individual drivers. There is another program you can use to detect system hardware and software much like everest. this program is called siw.
May 05, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Need sound drivers
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
63
Dec 30, 2008 | Intel Motherboard
Toshiba Satellite A100 PSAAKC - No sound after Vista to XP switch
Ok so im not sure if anyone i still reading this post or not but i have the same issue with a downgrade from vista to XP
here is what i did
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PFid=24&Level=4&Conn=3&DownTypeID=3
Windows 2000, Windows XP/2003(32/64 bits) Driver only (Executable file)
i downloaded and installed then gave it a reboot and we have sound again :) not sure if this helps you or not but i will bookmark this post to see if this helps anyone so let me know :)
Jul 08, 2008 | Computers & Internet
Asus P5GD1-FMS 775 Intel 915GExp. need help..
v i i i
P5GD1-FM specifications summary
(continued on the next page)
CPU
Chipset
Front Side Bus
Memory
Expansion slots
Storage
High Definition
Audio
LAN
USB
IEEE 1394
BIOS features
Rear panel
LGA775 socket for Intel® Pentium® 4/Celeron processor
Compatible with Intel® Performance Universal FMB 2005
processors
Supports Intel® Hyper-Threading Technology
Northbridge: Intel® 915P Memory and Controller Hub (MCH)
Southbridge: Intel® 82801FB ICH6
800/533 MHz
4 x 184-pin DIMM sockets support unbufferred non-ECC
400/333 MHz DDR memory modules
1 x PCI Express x16 slot for discrete graphics card
3 x PCI slots
Intel® ICH6 Southbridge supports:
- 2 x Ultra ATA 100/66/33 hard disk drives
- 4 x Serial ATA hard disk drives
Realtek® ALC861 8-channel CODEC with Jack-sensing
and Universal Audio Jack (UAJ®) technology
1 x Optical S/PDIF out port
Realtek® RTL8101L LAN controller
Supports up to 8 USB 2.0 ports
T1 controller supports:
- 2 x IEEE 1394a ports
4 MB FWH, AMI BIOS, Green, PnP, DMI2.0, WfM2.0,
ACPI 2.0a, SM BIOS 2.3
1 x Serial port
1 x IEEE 1394a port
1 x LAN (RJ-45) port
4 x USB 2.0 ports
8-channel audio ports
Nov 24, 2007 | Computers & Internet
Intel D101GGC Motherboard Logo
56 people viewed this question
Top Intel Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
