HTC Amaze 4G Android Smartphone Logo
A
Anonymous Posted on Feb 05, 2018
Htc amaze battery life
Apparently the battery level showed on the phone screen indicator does not match with the real charge in my HTC Amaze. So, sometimes according to the screen I have i.e. more than 70percent of charge, and suddenly my smartphone dies and I must turn it on again. Is probably a battery failure..
tosin_christ
Level 2:
Sergeant:
  • Expert 242 Answers
  • Posted on Feb 05, 2018
tosin_christ
Expert
Level 2:
Sergeant:
Answers
242
Questions
0
Helped
45164
Points
822
Oops, it does not have to be, at times, I meant, supposed battery failure
If the battery contacts/pins for your phone/tab are not making contact well with the battery terminals/heads...you will experience such, constantly.
If the battery does not sit/fit well in its compartment, you will still experience same as you do at present. This is because, the battery is making partial contact with the terminals/pins.
Check these; whether your battery sits well and fits perfectly in its compartment inside your phone/tab.
Check whether the terminals are contacting well
Aside of these, you may need to either replace your cellphone/tablet's battery and watch what happens.
1 Related Answer
jasond2255
Jason Darren
  • 56 Answers
  • Posted on Apr 19, 2013
SOURCE: i need to unlock my HTC Amaze 4g for free
What usually Free Unlock Code providers do?Usually free service providers make u sign up or other schemes to get a lead from you and promise you to unlock code.
Do they give unlock code?No, they will give you fake unlock code and instructions to unlock your phone. You phone will show error in this case.
What can be the result?
You may end up hardlock the phone. Which means that the phone will never get unlocked from this network provider OR might be that you may need to get it mod and get it to work, which I don't suggest personally after having 5 yrs of unlocking experience!
Solution?
Go for a reliable unlocking service provider who provide genuine unlock code for your device to unlock it safely.
Click to unlock HTC Amaze 4G from your network provider!
Htc tablet pg41400 restrat problem
it might be problem with system software... i think
it wants to reload the operating system...
Reset password htc phone
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
  1. With the phone turned off, press and hold the VOLUME UP and DOWN buttons, and then briefly press the POWER button.
  2. Wait for the screen to show the instructions on how to do the factory reset, and then release the VOLUME UP and DOWN buttons.
  3. Follow the instructions onscreen to factory reset your phone.
2helpful
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
I connect my HTC HD7 from a wall charge and is not charging.
it sounds as thow you got a faulty wall charger it happens a lot, and if its not than your battery is gone that happens when you leave it plugged up after its fully charged, it over heats the battery and eventually it will not charge
My HTC Amaze shut down and wont turn on or charge even with battery change
Try leaving it on the charger for a few hours and see if that helps.
Htc amaze 4g wont turn on after charged
Try leaving the battery in with it charging all night, if the phone won't turn on after that, you'll need to exchange it.
3helpful
2answers
I connect my htc sensation xl to the pc and its not working, instead my phone turns very hot
Whenever you connect HTC Sensation XL with Beats Audio to a computer using the USB cable, the Choose a connection type screen opens and lets you choose the type of USB connection.Select one of the following choices, and then tap Done:Charge onlySelect this option if you only want to charge the battery while connected to your computer.Disk driveSelect this mode when you want to copy files between HTC Sensation XL with Beats Audio and your computer.
When on Disk drive mode, you will not be able to use apps on HTC Sensation XL with Beats Audio that access the storage such asCamera.
HTC SyncSelect this option to synchronize contacts, calendar, and other information between your computer and HTC Sensation XL with Beats Audio.USB tetheringWhen you do not have an Internet connection on your computer, you can select this mode to share the mobile data connection of HTC Sensation XL with Beats Audio with your computer.Internet pass-throughIf you don't have a data plan or you don't have access to a Wi-Fi network, you can select this mode to share your computer's Internet connection with HTC Sensation XL with Beats Audio.
2answers
I need to unlock my HTC Amaze 4g for free
Dont try to unlock your phone with free unlockcodes which you get from some sites.entering wrong inlockcodes will brick your phone or it will be hardlocked. so its a better idea to buy unlockcodes from any trusted online vendors.
From my personal experience i would recommend http://unlockgenie.com/.
i unlocked my HTC AMAZE 4G with their help. i placed the order and i got my unlockcode along with the unlocking instructions to my mail address. the code worked fine and now i am using my HTC with my favourite network provider
Top HTC Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Sean Wright
Sean Wright
Are you a HTC Tablet and eReader Expert? Answer questions, earn points and help others
