Question about Weiser Lock POWERBOLT ELEC DEADBOLT
I have a weiser powerbolt lock on my door the lock works fine to lock and unlock but the alarm goes off every few minutes no matter if the door is closed and locked or open.
I've changed the batteries twice and reprogramed the key pad but the alarm still goes off.
5 Related Answers
Anonymous
  • 68 Answers
SOURCE: center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
Posted on Mar 23, 2009
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: How do I reprogram the
  • Remove the inner cover plate from the lock.
  • Locate the small round reset button near the left side of the circuit board (Red or Black).
  • To program, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
best of luck.
Posted on Aug 02, 2010
Coaltowner
  • 963 Answers
SOURCE: Touch pad does not work on weiser lock powerbolt.
I found this Frequently Asked Questions sheet for the Powerbolt 1000:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
I hope this helps.
Posted on Mar 05, 2011
papouducafe
  • 15 Answers
SOURCE: i have a weiser lock
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Posted on May 15, 2011
Coaltowner
  • 963 Answers
SOURCE: After replacing the batteries on
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
  1. Take out batteries and unplug powerstrip.
  2. Let it sit for 1 minute, then put the batteries back in and wait another minute.
  3. If it does not beep, the keypad needs to be replaced (17733-1).
  4. If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
Since you've already gone through the battery change, this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
I hoe this has been helpful. Good luck!
Posted on Jun 24, 2011
I guess I need to purchase a new cap that goes over the pins. Mine is missing and my door unlocks when the lock button is pushed,
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
Sep 05, 2012 | Weiser Lock Powerbolt 1000 Lock
Weiser Power deadbolt works backwards on keypad
Aug 18, 2012 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Batteries were wearing out and were replaced. Has not worked the same since. Green light on the back continually flashes. When code is entered to unlock sometimes it works on the first try-- sometimes the...
I recommend that you got to this link:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
and contact Weiser Lock for technical assistance. Yours is an uncommon problem.
Sep 20, 2011 | Weiser Lock GED1460X GED1460X15A Antique...
My Weiser Lock unlock fine using the touch pad but will not lock using the touch pad lock button
For your unusual problem I suggest that you call Weiser Lock during business hours at one of these numbers:
For assistance call
1-800-343-9652 USA
1-800-501-9471 CANADA
or visit www.powerbolt.com
Sep 12, 2011 | Weiser Lock GED1460X GED1460X11P Venetian...
Weiser powerbolt worked well for several months but now is not reliable anymore. Changing batteries did not help. It sounds like it is locking but sometimes fails to lock...we cannot trust it anymore
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Good lock or good unlock
Feb 05, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
My lock, weiser lock Powerbolt, right now is locking from left to right. I installed the double-door. The lock requires locking mechanism from right to left. How do you program it.
I think this link answers your question:
Jan 29, 2011 | Weiser Lock Powerbolt 1000 Lock
Key pad freezes up and unit goes into an alarm mode. My unit is only a few months old. Thanks Marc
Weiser has a one year warranty against electronic problems and a lifetime warranty for mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Nov 23, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser Lock keyless entry alarm is goes on and off randomly
Same here. I have found that unplugging the keypad connector relieves the beeping problem, but of course this isn't a solution except to suggest that the keypad is the culprit. Perhaps a replacement keypad is needed? Contact their customer service - http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Oct 01, 2010 | Weiser Lock Powerbolt 1000 Lock
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
Center button unlocks insted of locks code locks insted of unlock
Jan 22, 2009 | Weiser Lock Powerbolt 1000 Lock
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
95 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
