Question about Nokia N70 Cellular Phone
Nokia N70 memory
My phone keeps coming up with "Not enough memory to perform this action, please remove data".  I have tried to delete messages from my inbox but it won't allow me to do this.  I have tried switching the phone off and back on then but i keep getting the message about the memory.  Do you have any suggestions?
Posted by kate3012 on
  • owenow Dec 07, 2007
    I'm facing the same problem as kate. i've tried clearing my inbox, transferring and storing all video, sound and pic files to my external memory card. but the problem persists. i've even cleared my calender notes which take up very little space... might this be due to hardware prob or virus infection? pls advise. thnx!
Michael Lugassy
  • 55 Answers
Move pictures, videos, applications and sound files onto the FLASH card. I believe most of them are stored on your phone/sim-card. Simply browse for each of the files and select move.
Posted on Oct 23, 2007
  • Kid-_-me Jul 15, 2011
    hey dude,u need to have memory two times the size of file to be copied,suppose if u want to copy 5 MB file,u need to have 10 MB free...
Anonymous
    New Friend:
Camera not working msg says hardware failure. restart camera
nokia 70
Posted on Jan 23, 2010
Anonymous
You do one thing change ur message memory from phone to memory card.then it will solve ur problem.
To make the change just do like this: go to messages folder,at the right u see the options button click on to it.
options->settings->other->here change memory inuse as memory card
Posted on Oct 26, 2007
Anonymous
Moving pictures, and all the files might just work but it will be stored on your phone memory so the best way to git rid of it is to try putting up some applications that will automatically save all the files that are sent thru mms, bluetooth, etc... try fileman.....
its better than the built-in file mngr of your phone. GAINTECH
Posted on Oct 25, 2007
I can't send messages keep getting the message not enough memory to support operation delete some data?
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Aug 02, 2012 | Nokia E5 Cell Phone
I have a nokia c5-03 and i get the message:not enough memory to perform operation.delete some data first but i cannot enter anywhere(in settings) or application manager,etc because i get this error. also...
If the phone notifies you if the phone memory is getting low. To free phone memory you have the following options:
  • Move data that you want to keep to an alternative memory (mass memory or memory card, if available) or to a compatible computer.
  • Remove data you no longer need.
Use File Manager or the respective application in your phone to remove data or to move data to alternative memory as described in the user guide. Typically you first mark files to be removed or moved and then you select the corresponding option (Delete orMove to folder).
Use Nokia Ovi Suite to move data to a compatible computer.
In order to free phone memory, you could remove or move the following:
  • Messages from Inbox, Drafts and Sent folders in Messaging
  • Retrieved e-mail messages from the phone memory
  • Saved Web pages. Clear the web browser cache to free some phone memory (e.g. select Options > Clear privacy data >Cache).
  • Saved images, videos, or sound files (in Gallery, Photos,Videos or Music player)
  • Contact information (in Contacts)
  • Calendar notes (in Calendar)
  • Downloaded application packages
  • If there are applications which are not needed any more, uninstall them with Application Manager
  • Any other data that you no longer need
If you are deleting multiple items and any of the following notes are shown: Not enough memory to perform operation. Delete some data first or Memory low. Delete some data, try deleting items one by one (starting from the smallest item). After deleting data, restart (power off/on) your phone.
Tips: Use the memory card or mass memory instead of phone memory in the Camera or other applicable applications in case the selection is available (e.g. via Options > Settings >Memory in use).
I hope this helps!!
Aug 06, 2017 | Nokia Cell Phones
My nokia N72 showing in the screen ''massaging not enough memory to perform operation.delete some data first'' when i want to write msg.
sir delete the inbox,sent message,outbox,draft,messages to get the enough memory from the phone and then you can send the message...........
Nov 22, 2010 | Nokia N72 Cellular Phone
Nokia N70.sms sned and recv problem showing delete some data
try to reformat your phone first turn off your phone and press hold * 3 call sign and turn on your phone you must hold press those key until your phone is reformatted
May 25, 2009 | Nokia N70 Cellular Phone
Can not send or receive sms.though memory space is free 746Mb
Here "Not Enough Memory" Suggests either the SIM Memory is full or the Phone Memory is full. It has nothing to do with te Memory Card.
As you say there is only one SMS in the INBOX, I suggest you check the SIM Memory. It will be full. Delete some data from SIM memory. It shud work
My problem is my 3230 cellphone sometimes it appear memory full closed some application.
You may want to delete the following items regularly to avoid memory getting
low:
• Messages from the Inbox, Drafts, and Sent folders in Messaging.
• Retrieved e-mail messages from the phone memory.
• Saved browser pages.
• images and photos in images.
To delete contact information, calendar notes, call timers, call cost timers, game
scores, or any other data, go to the respective application to remove the data.
If you are deleting multiple items and another of the following notes are shown:
Not enough memory to perform operation. Delete some data first. or Memory low.
Delete some data. try deleting items one by one (starting from the smallest item).
Clearing the calendar memory - To remove more than one event at a time, go to
the Month view and select Options→Delete entry→
May 04, 2009 | Nokia 3230
My N73 phone has problem.Its memory always states "NOT ENOUGH MEMORY TO PERFORM OPERATION DELETE SOME DATA FIRST.I already deleted many datas like pictures and music..but it is still the same. please help...
My N73 phone has problem.Its memory always states "NOT ENOUGH MEMORY TO PERFORM OPERATION DELETE SOME DATA FIRST.I already deleted many datas like pictures and music..but it is still the same. please help me.
Jan 05, 2009 | Cell Phones
Low memory in my nokia 7610, how to delete some data (messages)
give it a soft reset then try to mark all th e messages and delete them for once
*#7370# then yes then 12345
u might need a memory card
Aug 15, 2008 | Nokia 7610
Saving problem
Go to message setting and Change the memory in use to memory card instead of Phone
in your phone it is using phone memory for incoming messages ,. THatis the Problem,
Jan 21, 2008 | Nokia N72 Cellular Phone
Cannot delete messages from inbox
It also happened to me and my friend's cellphone. I suspected a virus from a text message we received. You have to reformat your phone as suggested by iroarload: 1. switch phone off, probably take out the battery if the power button doesn't work. 2. hold down call (green), 3 and * all at the same time. best with right hand. 3. turn phone on. with left hand. 4. wait a bit and phone will come up with formatting. does take a bit, so be patient.
May 25, 2007 | Nokia 3230
Nokia N70 Cellular Phone Logo
184 people viewed this question
Top Nokia Cell Phones Experts
Ekse
Zaid Anarwala
Zaid Anarwala
SANTHOSH
