If you keep blowing the brake fuse than you have a short in the system. Unplug the brake switch. Install a new fuse. If it did not blow than the problem is after the brake switch. Next unplug the turn signal switch, then plug the stop light switch back in and press the brake pedal. Did the fuse blow. If not than the wiring is good in between the two switches. With the turn signal switch disconnected use a jumper wire in between the light green wire (power from the brake switch) and the orange with light blue wire (power to the right brake lamp). If the fuse blows than there is a short in the right side brake circuit between the plug in and the rear socket assembly. If the fuse does not blow than jump from the light green wire to the Light green with orange wire (power to the left brake lamp). If the fuse blows than the problem is in the left hand brake wiring circuit.
Reseat and check ALL cables. Reboot the ISP modem and router. Contact the ISP to analyze the signal, have a ISP tech come out to verify the signal, it may be outside equipment.
i had same problem today, it had locked up during deal/no deal unplugged it three times nothing happened, wouldn't switch on unplugged again left it for 5 minutes then plugged in and left alone for 15mins plus lights flasing then evetually green light went all ok
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
There are many things that can be causing this. Like; wired/wireless, if wireless how far away from your access point or router is your pc or you may need another access point for a stronger signal. Also try moving your pc when you loose your signal. Just a little repositioning might grab a stronger signal. Your modem: Try unplugging it when this happens wait for about 1 min then plug back in. You may be in an area that's causes "bottle necking" a term used for clogged internet signals. This usually happens during weekends and peak internet usage hours. This would be a job for your internet provider. There is also a reset on your modem. If unplugging doesn't do it after all the lights have come back on and the internet light stops blinking, look for a very small hole somewhere on your modem (not router). Get an object small enough to fit into it and strong enough to add pressure. Tooth picks won't work! Now push it in (while turned on) and hold it until all the lights go off. It may seem like it takes forever, just be patient. Once all the lights go out let go of the reset; wait again for all the lights to come back on & internet light to stop blinking.
If still same problem could possibly be your ethernet/wireless card going bad but they just kind of either work or they don't.
Start keeping tract of the times/days this happens and how long your internet is down. I'd do this for 1-2 days then call your internet provider. Theres one catch with them tho, they can't see your problem or diagnose it on their end unless your down at the time you call them. You may just need another modem. But keep on them if you come to this step. They like to say "ok your good now - bye" and then you'll have the same problem again. If this happens demand a new modem. It's free...
