Question about Texas Instruments TI-83 Plus Calculator
Check battery - Texas Instruments TI-83 Plus Calculator
Posted by Miranda Lee on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
If the battery level drops to a certain level the calculator will tell you so when you turn it on. Otherwise there is no battery status indication.
If you really want to know the battery level, take the batteries out and check them one by one with a voltmeter.
Posted on Jan 24, 2014
The non replacable battery on my Toshiba CL 151 B1204X will not charge or operate on battery
the battery problem arise vy bad battery or incompatible battery. also there may error on charge circuit. to check pls remove the battery and plug ac adapter , close the lid and turn it , check battery outer 2 pins on the laptop by multi meter ,it have to be set up 1or 2 volt than the battery output current.
but measure DC Volt near 19V. or laptop input DC voltage pls check the battery charge circuit and repair, also pls plug the battery to another compatible laptop and check.
Sep 25, 2017 | Toshiba Computers & Internet
I have an error code of FOO ?
Joseph, No F00 maybe contact company. Digital Battery Charger Error Code Explanation Chart. Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ERROR CODE DESCRIPTION REASON/ SOLUTION F01 The battery voltage is still under 10V (for a 12V battery) or 5V (for a 6V battery) after 2 hours of charging. Could be caused by trying to charge a 6V battery on a 12V setting or charger, or the battery could be bad, have it checked or replaced. F02 The charger cannot desulfate
the battery. The battery could not be desulfated, have it checked
or replaced. F03 The battery was unable to reach the "full charged" voltage. Could be caused by trying to charge a large battery or bank of batteries on too low of a current setting or the battery may have a shorted cell. Try again with a higher current setting or have the battery checked or replaced. F04 The connections to the battery
are reversed. The battery is connected backwards. Unplug the charger and reverse the connections to the battery. F05 The charger was unable to keep the battery fully charged in maintain mode. The battery won't hold a charge. Could be caused by a drain on the battery or the battery could be bad. Make sure there are no loads on the battery. If there are remove them.
If there are none, have the battery checked or replaced. F06 The charger detected that the battery may be getting too hot (thermal runaway). The charger automatically shuts the current off if it detects the battery may be getting too hot or the battery may have a shorted cell. Have the battery checked or replaced.
FAQS
Schumacher XP2260 Owner Manual
XP2260W Schumacher Portable Power 1200 Peak Amps
Mar 05, 2016 | Schumacher XP2260 6-in-1 Jump Starter
One red light flashes. I know the batteries are charged 17v. I've checked all connections. apmeter reads zero. What else should i check?
17 volts is a sign of one battery bad, or both. How old are the batteries? Check each battery separately for at least 12v. Check at the batteries themselves. If you don't get the 12 or greater reading replace the batteries. If you don't have insurance check at batterysharks.com.
Jan 20, 2015 | Pride Jazzy 1103 Ultra Standard Power...
Sits overnight and battery drains
Did you check the battery? Take the car and have a load test preformed on it, simply checking the volts will not tell you how the batt is doing.
Also check for any trunk lights, hood lights, glove box lights that are not going off.
Hope this helps.
Dec 29, 2012 | 1992 Isuzu Rodeo
Starting problems
WHEN HAVING STARTING PROBLEMS.FIRST OF ALL CHECK BATTERY CABLES IF THEY LOOK VERY OLD HEAVILY CORRODED. REPLACE THEM.IF BATTERY CABLES GOOD AND TIGHT.CHECK BATTERY VOLTAGE.IT SHOULD BE 12.5 VOLTS.IF NOT CHARGE CHECK BATTERY OR REPLACE BATTERY.IF BATTERY CHECKED OUT GOOD. REMOVE HAVE STARTER CHECKED OUT AT ANY AUTO PARTS STORES.THEY WILL DO IT FOR FREE.DUE TO LOCK OUT FEATURE TURN OFF RADIO FIRST BEFORE REMOVING BATTERY NEGATIVE CABLE.THIS WILL KEEP YOU FROM LOSING RADIO PLAYING CODE.
Jun 16, 2010 | 1995 Volvo 940
MY BATTERY INDICATOR SAYS PLUGGED IN BUT NOT CHARGING
i suggest you to perform the battery health check to the battery status.
1.click on start -> type battery check in the search field and then click on battery health check to perform battery check.
Jun 15, 2010 | HP Pavilion dv7-1468nr Notebook
Hi my battery (for hp batteries hp pavillon dv 6500 notebook pc ) charges only 10% thought I replaced my power adapter
Perform a battery health check.
Using HP Battery Check
HP Battery Check is a tool that provides information on the status and condition of batteries installed in a notebook PC. It is available on all Windows Vista HP notebook PCs.
To launch HP Battery Check, follow the steps below.
  1. Click Start and then HP Help and Support .
  2. Click Troubleshooting Tools , and then under Battery Check, click Use this tool to test how well your notebook battery is functioning .
Alternately, click Start , All Programs , HP , and then HP Battery Check .
HP Battery Check opens.
If the battery fails then contact HP.
May 22, 2010 | HP Pavilion dv6000z PC Notebook
Battery
The mechanic should check the battery if it is full charge or not . the battery should be inspected if it is corroded , lock of battery water or distilled water. then check the battery plate the one that divide the water in the battery check it if dirty or corroded . If these parts of battery are worn out or destroyed , then replace them.After checking the battery or after inspecting the battery then charge it fully on electricity .After it you still have to check the car's ignition system . check for loose wires or worn out fuse.from ignition switch , ignition coil , spark plug , distributor assembly.You have to check these for to be sure that when your going to start the car it will start properly. those loose wires you have to re connect them ,those worn out fuses replace them. Then place the battery back to its place.
Sep 01, 2009 | 1987 Ford Mustang
Black and Decker Battery Charger
Fault Codes Meaning of Fault Code F01 Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load. F02 Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair. F03 Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual. F04 Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual. F05 Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation. F06 Reverse Polarity F07 Alternator Output is Out of Typical Operation Range
Operation Codes I=I=I=I Battery Reconditioning - (The letters DES will display for the first three seconds) I-I-I-I Alternator Voltage Check OOO Charger Standby FUL Battery Fully Charged
Sep 21, 2008 | Electronics - Others
Texas Instruments TI-83 Plus Calculator Logo
383 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
