Printer prints only the header or top of the page being copied. Have cleaned nozzles and head aline but still no luck.
1. In Internet Explorer, try going to : 'File', 'Page setup' and check off the box for 'Print Background Colors and images'.
If does not work, go to:
2. In Internet Explorer go to 'Tools', 'Internet Options', go to 'Advanced' tab then go scroll down to 'Printing' and make sure box is checked for 'Print Background Color and images'.
3. If still not working, advise, you may need to take your ink out and use a syringe and mineral spirits to clean the heads of your printer (lots of times these get clogged).
4. All else fails, you can set your printer back to default settings, can find out how to do that over the internet.
One of these will fix your problem.
SOURCE: Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
SOURCE: CX7400 Epson printer will only print one copy at a time
If you are printing from your computer, in the print options select how many copies you would like to make in the preferences.
SOURCE: Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
SOURCE: epson stylus photo 2200 print head removal
Replace the cartridges.
Otherwise, it's unorthodox, but some users have found that this works in your situation. Remove the cartridge, cover the nozzle with a paper towel and use the pointed attachment of a vacuum to clean the dry ink from the cartridge. Be careful not to get ink all over. Then reseat the cartridge and print...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Using the Head Cleaning utility
Using the control panel buttons
If you find that the printout is unexpectedly faint or some dots are missing, you may be able to solve these problems by cleaning the print head, which ensures that the nozzles are delivering ink properly.
You can clean the print head from your computer using the Head Cleaning utility in the printer software or from this product itself by using the control panel buttons.
Note:
Refer to the appropriate section below to use the Head Cleaning utility.
Follow the steps below to clean the print head using the Head Cleaning utility.
Make sure that A4 or Letter size paper is loaded in the sheet feeder.
Make sure that this product is on and the ! Error light is off.
Access the printer software.Accessing the Printer Software for Windows
Click the Maintenance tab, then click the Head Cleaning button.
Follow the on-screen instructions.
Head cleaning... appears on the LCD panel while this product performs the cleaning cycle.
Caution:Never turn off this product while Head cleaning... appears on the LCD panel. Doing so may damage this product.
When Head cleaning... disappears from the LCD panel, click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Good: print head does not need to be cleaned yet.
Not Good: print head needs to be cleaned.
If the nozzle check page does not print satisfactorily, you may need to repeat the head cleaning and print the nozzle check pattern again. See Cleaning the Print Head.
Note:
