Question about Plumbing
Grundfos MQ 35 won't run
Pump only runs for a few seconds then shuts off. Turn off then back on and still only runs for a few seconds. Lots of water on supply side. Problem was intermittent but now is all the time.
Posted by Bob Martin on
Gil Shultz
  • 3,388 Answers
Sounds like the discharge is plugged. You can get the manual at: http://rainwatercollection.com/download/Grundfos-Manual.pdf
Posted on Jun 13, 2014
5 Related Answers
Anonymous
SOURCE: Grundfos Pump Wont Stop Running
Close the outlet valve then turn electrical switch on manual for a few seconds until any air is pushed out then open the valve and return electrical switch to automatic.
Posted on Aug 01, 2010
Anonymous
  • 42 Answers
SOURCE: My Grundfos MQ pump won't
There should be a small cap on the motor end of the pump, take that off and you will see the stainless steel shaft with a **** in it for a flat bladed screw driver. You should not need to turn the water off. A few drops might come out, but it's safe to do it that way. Turn the shaft with the screw driver and that should loosen up the pump.
Hope this helps.
Posted on Nov 05, 2010
HansPP
Hans Pearson
  • 2510 Answers
SOURCE: i have a grundfos mq
There was possibly some damage done to the pump while it was operating dry and it in now not able to deliver the required flow of water. Pumps wear very quickly when allowed to run dry, even for a short time.
Posted on Feb 19, 2011
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: I have a Grundfos MQ
If you have done all of that troubleshooting pressure testing input and output lines with no leaks then the air is being introduced via the pump itself. This can be a motor shaft seal or the stainless endcap seal of the pump is allowing air into the system. Under pressure while testing a shaft seal pressure may hold but during dynamic use (spinning) it may be allowing air into the pump ahead of the impeller. You have done the correct troubleshooting you may be having a difficult time realizing the problem is the pump itself. When I have to troubleshoot a hard problem like this I make a re-circulation loop restricting the output line and use a liquid soap. If the re-circulated water bubbles after adding liquid soap water in suspect seal areas external to the pump, then the seals are failing. Food coloring water works too, but can discolor floors tiles or work areas.
Thanks for choosing FixYa,
Kelly
Posted on May 12, 2011
thomas gowen
  • 92 Answers
SOURCE: Grundfos pump switches on & off continuously with
if you have a pump for the whole house you need to check the bladder tank. there is a air valve on the top. Check the pressure with a tire gauge you should have at least 20 PSI this will stop the pump from the on and off thing.
You can compress air yuo can not compress water. thats why the ballder tank. As the pump work to shut off pressure it is compressing air. then when you use a little water the pump does not run until a large about is run then the pump will re fill the system
Best of luck
R J
Posted on Sep 08, 2011
Grundfos pump
Louise, since there is several different types and models of Grundfos pumps it would be hard to answer your question. To possible point you in the right direction below are a few links to where you can find some PDF documentation about a popular Grundfos pump the MQ series and direct link to the manufactures "Service Support".
Service support
Grundfos MQ Series Pumps
Feb 07, 2014 | Garden
Grundfos MQ pump starts every 15 seconds
Pressure is bleeding back through the pump or system to the tank or well or where ever the water is coming from. Should be some sort of one way valve to keep water from going back to the source, mounted somewhere so that once pressure is pumped up, it will hold that pressure in the part of the system that has the pressure switch that controls the pump.
That or you have a leak where you can't see it. (Actually you do, it is just internal and not leaking outside the pipes!)
Nov 04, 2012 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
I have a problem with mq booster pump every 10 seconds kicks back and kicks on i am check the showers no leaks everything is ok please tell what can be a problem
Grundfos said the problem of on off every few seconds was air in the line. Then
later admitted it was the control unit. After replacing two units in 2 yrs I replaced
it with a standerd pump pressure switch.....Runs fine
Nov 17, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
When I turn on the water in the house, my pump will turn on and begin running for about 15 seconds, it will turn off for about 2 seconds, and then turn back on for another 15 seconds. It consistently does...
If there is a surge tank in the system this is not working.
Try raising the cut-out pressure. It sounds like the pump is reaching high pressure even when you are using water.
Gary
Jan 05, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
I have a grundfos mq 35 pump to boost pressure in my hot and cold system. due to loss of water recently pump ran dry and shut down. when water returned the system was restarted and pump reset. we now get...
Jan 02, 2011 | Grundfos JPS4 1 HP Pressure Booster Pump
I have a problem with the MQ-35 pump starting and running for about 10 minutes when there is constant demand (such as running a sprinkler) and it then alarms and shuts off for 30 minutes before it will run...
This sounds like a issue with air still being in the system and not being removed from the system to make things work properly. I did try to findthere number and was unable to locate it. The only other option for you is to return the product and find one with better support
May 04, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
With the water running the MQ pump runs intermittently
This is a problem with your bladder in the pressure tank or the pressure switch. Ether one will produce this cycling on and off. Good luck.
Mar 09, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
My Grundfos MQ pump intermittantly continues to run when there is no demand, especially after drawing off a small quantity of water. It then overheats. The plumber has replaced the pressure tank but the...
I have the same problem and have found that the inlet check valve has a broken shaft in the center of device. It is a multi-piece plastic unit and it looks as if it is not quite seating and therefore the internal pressure leaks slowly back into my low pressure suction line. The pump will start and the pressure will build then shut off for about 30 minutes then cycle again. I am going to replace the check valve.
Mar 06, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Plumbing Logo
277 people viewed this question
Top Plumbing Experts
Bill Johnson
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
