I turn the heating/air fan on, the fan will not go
The heating/air fan will not go on; the yellow light on the air conditioner as well as the yellow light on the air circulation button start blinking. I have the same problem with mine. I thought it was the blower motor, but then I had taken it to a guy who knows a little bit more about Volvos than I do. And he told me that it was the auto-climate-control-unit and not the blower motor. I called the dearlership and was told it would be around $2500.00 to order a new one. I was able to able to order a used one off ebay for $30.00. I got it today and just hooked it up, and it's the same problem. So maybe it is my motor or I bought a nonworking unit.
The same guy who told me it was the unit, also told me that when those two lights start flashing it means your unit is fried.
Where would this be located at? And how much would it cost? I live in a small city, there's not any mechanics that know anything about a Volvo. And the one dealership that sells them is predominantly a Chrysler dealership, so the mechanics there don't know a thing either. I called the junkyards here and they don't have any S70s. I'm a college student working part time in the mall. I barely make enough to fill my tank with premium, let alone pay an outrageous amount to have it fixed.
You can't post conmments that contain an email address.
completely understand that, if my junyard specialized in volvo i would help you out but were all about toyota here. Its more like a computer that controls it all. that is bad.
MIKEcompletely understand that, if my junyard specialized in volvo i would help you out but were all about toyota here. Its more like a computer that controls it all. that is bad.
MIKE
a fuse number 24,,,
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses
Rating
Color
Circuit
Engine bay fuse box
Black
Power supply to main fuse box
Yellow
Radiator fan
Yellow
ABS
Yellow
Daytime running lights
5
30
Light green
Fog lamp
6
30
Light green
Not used
7
30
Light green
ABS
8
30
Light green
Air pump
9
20
Light bue
PCM module
10
20
Light bue
Ignition switch
11
Violet
PCM memory
12
15
Light bue
Horn & hazard flasher
13
15
Light bue
Oxygen sensor
14
15
Light bue
Fuel pump
15
10
Red
Right-hand low beam
Passenger compartment fuse box
16
10
Red
Left-hand low beam
17
10
Red
Right-hand high beam
18
10
Red
Left-hand high beam
19
7.5
Brown
Heated door mirrors
20
10
Black
Windshield wipers
21
30
Light green
Electric windows
22
7.5
Brown
ABS
23
15
Light bue
Reverse lights
24
15
Light bue
Brake lights
25
20
Yellow
Door locks
26
20
Yellow
Main light
27
15
Light bue
Cigarette lighter
28
30
Light green
Power seats
29
30
Light green
Heated rear window
30
7.5
Brown
Engine management
31
7.5
Brown
Instrument pannel lights
32
7.5
Brown
Radio
33
7.5
Brown
Front and rear sidelights (left)
34
7.5
Brown
Interior lighting & clock
35
7.5
Brown
Front and rear sidelights (right)
36
30
Light green
Air bag
37
30
Light green
Heated blower
38
Unused
Relays
Color
Circuit
Location
Engine bay fuse box
R1
Green
Daytime running lights (Canada)
R2
Black
Radiator fan (high speed)
R3
Blue
AC cut-out
R4
Brown
AC clutch
R5
Dark green
Radiator fan (low speed)
R6
Yellow
Starter
R7
Brown
Horns
R8
Brown
Fuel pump
R9
White
Low beam headlights
R10
White
High beam headlights
R11
Brown
PCM power supply
R12
White
Interior and courtesy lights
R13
Yellow
Heated rear window
R14
Yellow
Heated blower
R15
Green
Windshield wiper motor
R16
Black
Ignition
R17
Unused
R18
Black
One touch window switch
Driver's door
R19
Blue
Cruise control cut-off
Central fuse box bracket
R20
Unused
R21
Unused
R22
White
Fog lights
Interface module bracket
R23
Black
Turn signals
Steering column
R24
White
Left-hand flasher
Door lock module bracket
R25
White
Right-hand flasher
R26
Unused
Bulbs / Lights
Wattage
Type
Low beam headlamp
55
9006 Halogen
High beam headlamp
55
9005 Halogen
Parking / Side light
5
2357A Wedge
Front turn signal
21
2357A Bayonet
Rear turn signal
21
1157 Bayonet
Tail light
21
1157 Bayonet
Stop light
21
1157 Bayonet
High mount stop light
5
2723 Bayonet
Fog/Driving light
55
893 Halogen
License plate
5
6418 Festoon
Reverse light
21
1156 Bayonet
Front sidemarker
5
2357A Wedge
Glove box
Map light
5
64111 Wedge
Dome light
10
6411 Feston
Step/Courtesy light
Trunk/Cargo area
Engine compartment
10
89 Wedge
Instrument-general
Automatic trans indicator
Normal, the ac heat exchanger condenser need air moving across the fins to remove the heat. While
moving in town the condenser isn't remove the meat that is building up the it's
aluminum fins. Even though the vehicle uses an electric fan. The fan is used to
cool the engine temperature. If you Toyota is equip-ed with automatic
transmission. The electric fan will need to pull enough air to cool the engine
temperature, automatic transmission fluid, air conditioner condenser, and maybe
power steering condenser to cool the power steering fluid. Later model of
vehicles/trucks are using different refrigerants instead R134A in which you
Toyota uses.
The simples way to explain is the ac remove heat from inside your Toyota and this heat is removed by the refrigerants inside your ac in the car. To cool the refrigerant this coolant is removed to the heat exchanger condenser located in front of the engine radiator. So, while moving at 60mph there is enough air flow through the radiator, ac head condenser, and other aluminum heat exchangers. GB...stewbison
Several things ... best guess, in order: 1. (very likely) Radiator fan is not blowing (turn on car and a/conditioner. When compressor kicks in, the radiator fan must blow). If it ims not blowing, the radiator fan motor may be burned out ($40). 2. Check / replace "cooling fan" fuse ($1) and / or "cooling fan" relay switch ($7). 3. Radiator clog (possible) Hope this helps!
1. Does the cooling fan turn on when it over heats? 2. Check your coolant level, if it is a little low it will cool normally under transit and over heat in the conditions you are describing. Also have your coolant check for proper dilution. 3. If your cooling fan is failing to turn on you may have a coolant temperature switch issue.
If the fuse is blowing there is too much resistance in the cooling fan moter. Replace JUST the cooling fan motor and the fuse. The A/C always turns the cooling fan ON when turned on. That is why the A/C messes up when the fan motor is bad. Replace the fan motor and the A/C problem will be fixed too. :)
