Question about Apple MacBook Air 13.3" Core 2 Duo 2.13GHz/2GB/128GB SSD/nVidia 9400M Mac Notebook
Macbook Air 13.3" Not recognizing internal ssd
System turns on. Both resets SMC and PRAM don't do anything. Sometimes the drive is found when using the option boot somtimes it is not. You cannot install new OSX onto new drive but you can boot from some of the drives.
Posted by Juan Calderon on
ChrisTopher
    New Friend:
  • 3 Answers
I use an external drive to boot from with Techtools 7 installed. I would test permissions, and then file integrity and see what it finds.
If the OS is corrupt it will prevent bootup. It could also be a failing SSD. First try Holding down "D" immediately after the dong sound and the Apple hardware test will start. Use the arrow key to choose your language.
Follow the instructions and when it is done it will show an error code if there is a problem. Post that code and I can give you more info on the problem. Chris
Posted on Jan 24, 2014
5 Related Answers
Jesse Techno
JT Features
  • 19 Answers
SOURCE: Macbook keeps restarting
all macbooks have a security that will not let you switch the harddrive from one the the other.  Apple will need to reset the computer at an Apple store!!!  His drive is DEAD!!!
Posted on Nov 11, 2008
Anonymous
SOURCE: Flashing folder icon at startup
Fixed it myself. Here's how:
Put a DVD of Mac OS Leopard in the optic drive and restart with the C key held down. THIS time it responds and gives me a complete launch, however I did have to reformat the Hard Drive using the Disk Utility on the OS disk. It also required me to use the GUID table format on the options menu button... look for it...
Then after reformatting, I was able to reload the OS and at least I was able to save a MOBO swap...
Cool beans and I'm up and running..
Posted on Dec 15, 2008
Anonymous
  • 40 Answers
SOURCE: no sound from external speakers using macbook 13
go to system preferences and select sound button
check out the output tab int window, if output volume is disabled it means there is some problem with hardware. I had a similar problem it turned out that speaker wires where disconnected.
Posted on Jul 02, 2009
Anonymous
SOURCE: Intel Macbook Flashing Folder, wont boot DVD
Just a note--any Universal retail OSX install disc will work. It's only a machine specific disc that won't unless it's for your model.
Posted on Jul 08, 2009
crazytony777
  • 257 Answers
SOURCE: Error Loading Driver, Will Not Boot
do you have the restore disk to this computer if reload all
Posted on Aug 11, 2009
Colored circle comming up
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Locked
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
World icon with exclamation mark in the center macbook
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Can not click on icons
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
2helpful
Why does my SSD cause the beach ball of death on OSX?
Try a NRAM/PRAM/SMC reset.
The best thing is to get a copy of OSX 10.8 3, load it to a flash drive or burn to disk, then secure erase the SSD with the erase tool from Crucial, do a fresh install of OSX.
Then do a reset of these again, its the best way to get the system working with no problems.
That is a good SSD.
Just google NRAM/PRAM/SMC RESET and read how for your Macbook pro.
Then get a small external drive for backups, so you can secure erase the drive when needed.
Remember Apple turns off TRIM when its not one of their SSD's, so you need to give the drive time to use garbage collection.
You can Google TRIM enabler, but if you have any problems after installing it and turning it on, just turn it off.
I have no problems with it.
A new update for 10.8.3 is coming soon to public, beta 12D76 is working great.
Forward slash not working on my macbook air
Did you change the system font to one you downloaded from the Internet? Some of those are missing characters. If not,
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Keyboard not working
If you were using a bluetooth keyboard, it may still be looking for that keyboard.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Three-finger swipe between desktops not working as expected.
I'd try adjusting your setting in
Apple menu
System Preferences
Trackpad.
Not sure what key combination can affect those settings.
If that does not help try resetting the PRAM and or the SMC.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
My apple macbook air shows a question mark when i turn it on
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Apple MacBook Air 13.3" Core 2 Duo 2.13GHz/2GB/128GB SSD/nVidia 9400M  Mac Notebook Logo
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
