Soyo SYTPT3227AB 32 in. LCD TV Logo
j
jack plante Posted on Jan 23, 2014
No clock on tv
I have no clock on my tv therefor i cant use my sleep timer
1helpful
Does it have a sleep timer?
hello!
yes, it has the one! you need to go to the menu, setup portion of that. you'll see: clock set, timers, etc. That's where you will find it. A bit complicated, but possible. If your remote lacks "sleep" button, get the one with it.
good luck,
Alex.
9helpful
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
How do I use the sleep timer? when I push the sleep timer button it gives me on time and off time to set. I dont know how to use this. Cant I just set sleep timer for 30 minutes to turn off? Thank you.
Hello
Before going to set the timer, you have to set the current time. Set it according to the manual with you. If the timer function work properly, there must be an uninerrupted power supply also. If the power goes off, the set time will also get resetted, and improper function will occur.
After setting the present time, set the "on" time and "Off" time. The TV will switch on at that time you set, and will switch off automatically after the end time. OK.
How do i set the timer? i use it for my alarm.
Which timer do you want to use? To use the On/Off Timer, press Menu and use the navigation arrows to select Time. Press Enter and navigate (up/down arrows) to select either On Time or Off Time. Press Enter and then use the up/dwon arrows to select Repeat. Select the frequency for the timer function (off, once, everyday etc.) with the left/right arrows. Use both the up/down and left/right arrows to set the time (hour or minute). Press Return to return to the previous menu and Menu to leave the OSD menus. For the On Time, you can also select the input source that will be shown when the TV comes on. (Select Input similarly to the above directions and set the desired channel if the source is TV.) The time must be for this to work (select Time and then Clock then Auto (gets the time from a digital channel) or Manual) and the TV must be in Standby mode for the On Timer to work. The TV will go into standby in two hours after coming on unless a button is pressed on the remote or the TV. The Off timer will override the TV On if they are set for the same time.
The Sleep timer is set in the same Time area or in the Q.menu (from the remote). Select Sleep time and then the length of time you want the tv to stay on before going to sleep. This is reset when the TV goes off.
The Shut-off time is set in the Time menu as well; select Auto Sleep. When this is on (on/off options), the TV will shut off after 10 minutes without a signal.
I hope this helps.
(you will have to reset the timer after a power failure)
Hi my rca truflat 20 inch tv stays on for about 30 mins then displays an analog clock and turns off
Your sleep timer is on. Hit menu, and poke through that and find the sleep timer settings. Sleep timer is something that turns the TV off after an amount of time that your do not interact with it.
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Sleep timer for ipod nano 3rd gen
Go to extras. Select clock. Press enter on you clock settings. Select sleep timer.
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Top Soyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
