Question about Hotpoint FFA90 Bottom Freezer Refrigerator
Why does hotpoint ffa90 fridge freezer keep beeping
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
Posted on May 07, 2007
Anonymous
  • 2702 Answers
SOURCE: hotpoint ffa90 fridge freezer
this is heat likley to be from the compressor,,,it may have burned it out as it was working its hart out trying to cool your house down all last night? never stood a chance did it?
Posted on Nov 19, 2009
Testimonial: "thanks for your help"
Anonymous
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
Fan not working, fridge not cooling anymore, freezer seems ok
Hotpoint Fridge Freezer RFA52 BUT I DONT KNOW WHERE IS THE FAN CAN SOMEONE HELP ME TO TELL ME WHERE IS THE FAN IN MY FRIDGE SO I CAN DEFROSE IT.
PLESAE EMAIL ME ON: [email protected]
MANY THANKS
Posted on Mar 01, 2010
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Mar 11, 2010
Testimonial: "Thanks, I have checked that, but the vent at the bottom of the fridge section is a rigid plastic grill, which doesn't, nor looks like it should move. "
rickead1
Rick Ead
  • 1998 Answers
SOURCE: i have a hotpoint ffa90 fridge/freezer .fridge not
hello jennie,
remove the rear panel on the inside rear of the freezer to assure that you dont have an icebuild up on the evaporator if you do have an ice build up this is mainly due to your unit having a defrost issue this is mainly caused by one of four reasons. The defrost thermostat, the defrost heater, the defrost timer all of these three can be checked by doing a continuity test on some units a defrost timer is not used and instead the use of an electrical control board is instead used also assure when you remove this panel that the fan behind that back wall in the freezer is also running if not replace the fan if you have no ice and the fan is working you would then look at the either the damper door on the inside of the refrigerator or the damper control. The freezer side of a refrigerator is the only side that produces the cold a small door opens and closes allowing the cold air to go into the refrigerator side when the unit gets to cold the door shuts and likewise when it gets to warm the door opens if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future Thanks Rick
here is also a link on why this happens and what the pieces look like http://applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm
Posted on Apr 07, 2011
1helpful
On my Hotpoint FFA90 fridge freezer occasional leaks occur at the bottom of the freezer where ice accumulates. The fridge section above is fine. Any suggestions?
There is one in the freezer section as well. It's a small white tube. I've had the same thing happen with mine. I just took everything out of the freezer, and used hot water. It's caused by condensation buildup in the drain tube, which then freezes, obviously because it is a freezer after all. Hot water usually does the trick. Just be sure to clean it up, and dry it off really well so it doesn't re-freeze and cause the same issue.
Hotpoint ffa90 bottom freezer only cools down to minus 4
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Hotpoint FFA90 fridge freezer, fridge not cooling but freezer OK, was told vent proabaly blocked and to de-ice. Turned appliance off for two days, turned back on worked fine for 1 week but now fridge is...
i have the same problem. took apart the vent in the fridge at the top and thought maybe it needed replacing as that controls the amount of cold coming up from the freezer, but there doesn't seem to be any cold coming through. does anyone know if this is 'blown' through by a fan of some sort?
3helpful
Fridge of my Hotpoint FFA90 fridge-freezer freezes
4helpful
2answers
Hotpoint ffa90 fridge freezer hi the fridge door was left open overnight but has been closed all day,the problem is that the fridge compartment is warm. The freezer seems ok
3helpful
2answers
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
2helpful
3answers
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Hotpoint FFA90 Bottom Freezer Refrigerator Logo
Top Hotpoint Refrigerators Experts
Dan Webster
Dan Webster
jdthefixer
Michael Thomas
Michael Thomas
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
