Question about Panasonic PT-51HX41 51" Rear Projection Television
Green hot My picture/color is good and converged. The GREEN is loud and does not seem to tone down unless I take color close to minimum. The TINT and SHARPNESS do not seem to work at all. I know I might need o-scope or other test equipment but does anyone have suggestion!! Thanks in advance.
  • Anonymous Oct 23, 2007
    If dark scene or Black and white picture the green color really stands out.
Vista Electronics
    Genius:
  • 1,694 Answers
Locate green screen control found behind speaker grill cover
and access panel lower front of tv......turn green screen ONLY
CCW a little.................T.
Posted on Nov 08, 2007
The screen has a reddish tint to it. Seems like a color issue and not sure what to replace. The picture works fine but everyone is red. Not sure if there is a bulb to replace or what? Any suggestions? This...
You need a simple color adjustment. (Color Calibration)
You don't need to spend money on this. Try it for yourself.
Your main problem is that your color temperature is set to warm.
You need to change temperature to COOL or 6500K depending, on how it is labeled.
You will see improvement, but there is a little more...
Move "Color" DOWN from it's current position (probably at 50) to somewhere between 30 and 40. (Just a couple of clicks above where the color rapidly washes out.)
At this point there will still be slightly unnatural color to skin tones, but all the artificial "sunburn" and blaring red will be gone.
Last (as far as color goes) move the tint 2 to 4 clicks toward green. This added green tint balances the color so that the flesh tones become completely accurate and realistic.
For even better detail, continue your home calibration here:
http://www.wowvision.tv/main.htm
Jun 13, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Green tint to screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2010 | Hitachi 42V710 42" Rear Projection HDTV
The picture doesnt seem to be clear and it has a green tint
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Hitachi 46F500 46" Rear Projection...
Color went bad. Has a yellow/green tint to
This seems like a convergence issue and will need to be serviced.
There might be a chance of repairing the old convergence board but you will need to have the Tv looked at to determine what part on the convergence went bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 20, 2009 | Toshiba 50HM67 50" HDTV
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
KV-32FS120 makes a loud noise and green tint when turned on
Loud noise is possibly made by Degausing Coil to demagnetize picture tube and its normal.
Green tint shows picture tube is bit weak in electron emission due to its age and takes time to present good white balance result (good colors)
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
White colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Jul 20, 2008 | Akai PT5598HD 55" Rear Projection...
How to adjust red blue green
if ur in service mode already..turn down all drive.green first turn it up until the desired intensity is achieve.then blue all the way until it almost blend the green.u must not see one color either too much green or blue.turn up red now,let it blend until u see a perfect black and white.note:make sure that the color level is set to minimum and tint to center. ihope i help u..
Mar 20, 2007 | Toshiba 43H71 43" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
90 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
