Question about Samsung SCX 4200 All-In-One Laser Printer
Error During Scanning
Please restart the program and/or switch the device off, then switch it on and wait while it warms up.
An error occurred during preview. If another program is scanning, please wait for it to complete and select "Preview" again.
  • Anonymous Mar 23, 2014
    an error occurred during preview if another program is scanning
Anonymous
I encontered the same problem using a cheap usb cable. I changed the usb cable with better one. Problem solved.
Posted on Jun 08, 2009
HEMANT GROVER
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 171 Answers
Please check whether any other scanner is installed or not .It might be creating the conflict.
Pls remove it.
Haoppy scaanning
Omnipresent
Posted on Oct 26, 2007
2 Related Answers
Anonymous
  • 161 Answers
SOURCE: Error during scan
I beleive you are running too low on memory. If it is not the case try this:
1. Make sure that you are using a good quality USB cable not exceeding 6ft.
2. Delete the complete printer drivers and SmartThru software.
3. Run a complete scandisk and defrag on your computer.
4. Reinstall the drivers and software.
Posted on Nov 02, 2007
Anonymous
DEFRAG??? why should this help?
Posted on Sep 07, 2009
I saw the error "an error occurred during preview. if the scanner is being used. please wait for it to complete the task.and then click preview" when iam attempting to preview the scanned pictur how c
If you continue to get this kind of error after restarting the computer, you may need to update the scanner's device drivers or reinstall the included software. You should also make sure only one program or application is attempting to use the scanner by closing all but the one program you are trying use with the scanner. One last note - always either let the program you are scanning to operate the scanner or let the scanner invoke its default application by pressing the scan, fax or copy buttons on the scanner. Do not for instance try and scan an image into a running program that initiates the scanning process itself while also invoking a scan from the scanner's control panel. The two operations will conflict.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 19, 2014 | Office Equipment & Supplies
Error sp305
Reset the job and reset the device.
An error has occurred in printing.
  1. Make a note of the error message (for reference later).
  2. If the error re-appears, please contact your local authorized sales/service representative or original point of purchase.
For the time being, try restarting the device:
  1. Press the Clear button to clear any pending jobs from the Printer.
  2. Switch off the device at the Red Power Switch, wait for 5 seconds then switch on again.
May 07, 2013 | Ricoh Aficio SP C410DN Laser Printer
Error SC305 on
May 07, 2013 | Office Equipment & Supplies
Whenever I switch on to start operating, during my waiting to warm up, it displays error code C-D369. and it doesn't function from there.
Error code reset:turn OFF the copier ,press and hold the Utility key to right hand,to left hand turn ON the copier,wait appaire on the display Trouble reset,touch the screen and turn OFF the copier.Wait 2 minute and turn ON.
Jan 17, 2013 | Konica Minolta bizhub C250 All-In-One...
I would like know the method for edit error of hp laserjet P3005n error 57.03. Please suggestion or method for edit to me Thank you .
Hello Niramon,
The error message hp laserjet P3005n error 57.03 is due to sub cooling fan (FM2) error has occurred. Fan operation is verified during device power up. Fan operation occurs only during power up or during a print job.Turn the device off and then on. Verify that nothing is hindering or blocking the fan. Verify that the fan is connected to connector J512 on the ECU PCA. You might have to remove the main cooling fan to see this connection. If the message persists, replace the fan.
Jun 13, 2011 | HP LaserJet P3005n Printer
My scanner is not working. Everytime I try to use it, it says; WARNING Error during scan. Please restart device and/or switch device off and then turn it on and wait until it warms up. This never works!
It shows the scanner goes jam in the system need to be handled technically, consult nearest Samsung service center.
Re-installation of drivers may solve the issue,
Good luck
Dec 07, 2010 | Samsung CLX-3175FN Printer
Problem is occured during installation of USB Mass Storage Device An error occured during the installation of the device Data error(cyclic redundancy check)
Try uninstalling the USB root hubs in the device manager and then restart. They will reinstall upon the restart.
It may also could be a bad power adapter.
Dec 06, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Keyboard cannot be install on rebooting
uninstal the drivers of keyboard from device manager and restart the system
Aug 14, 2009 | HP Business Notebook 550
Samsung SCX 4200 All-In-One Laser Printer Logo
997 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
