Question about Fitbit Zip Wireless Activity Tracker, Midnight Blue
Fitbit Zip messes up sync with website, bricks itself and gives a 5.72 version code
I've been using my Fitbit Zip tracker for a couple of months with no problem. Today, I was trying to sync it with the website, and it seems to have synced incorrectly -- the number of steps listed on the site for yesterday is not what the actual number was. Worse than that -- the tracker itself just shut itself off, and I can't get it to turn on. When I tap on it, every once in a while the screen will display the number 5.72, which I think is the current operating system version. Then it turns itself off again.
Posted by Danny Horn on
1 Related Answer
elix0411
Jose Cada
  • 3530 Answers
SOURCE: I have tried recharging my fitbit by docking it
Welcome to Fixya
Pushing the hole on the gadget is like resetting the unit. This usually fixed all problems that you might encounter to the unit, just like a reset button on the computer. If you already did that and there is no response from the unit, the problem is more of a hardware/internal issue. You might need to contact the manufacturer for repair or call the store and ask for replacement if it is still under warranty.
Thankl you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Jun 01, 2011
Fitbit has wrong time. How do I change it?
-Log in to your fitbit.com dashboard and click the gear icon in the top right corner. -Scroll to the bottom of the Personal Info page and modify your timezone. -After saving your changes, force sync your tracker: Click the Fitbit Connect icon located near the date and time on your computer. Click Sync Now.Oct 13, 2016
SOLVED: Correct time cannot be set on my Fitbit - Fitbit zip - iFixit
https://www.ifixit.com/Answers/View/.../Correct+time+cannot+be+set+on+my+Fitbit
Fitbit has wrong time Google Search
Jul 30, 2018 | Exercise & Fitness
How to change time on my fitbit watch. it is now 12:15 pm
hi Paul.
or try this link.
How to change time on my fitbit watch Google Search
Dec 06, 2017 | Exercise & Fitness
How do I change the time on my fitbit?
hi Elaine.
-Log in to your fitbit.com dashboard and click the gear icon in the top right corner. -Scroll to the bottom of the Personal Info page and modify your timezone. -After saving your changes, force sync your tracker: Click the Fitbit Connect icon located near the date and time on your computer. Click Sync Now.13 Oct 2016
or try this link might help you.
How do change the time on my fitbit Google Search
Nov 18, 2017 | Exercise & Fitness
I misplaced for several months but finally found! Battery says medium but I can't get the display to work
app shows battery charge on last sync. display does not work, because it is fully discharged. recharge and then resync.
Jan 21, 2016 | Fitbit Zip Wireless Fitness Tracker
My fitbit flex died - cannot wake it up; also it's tied to my cell phone and that doesn't respond - totally blank!
How to fix broken Fitbit - sync Fitbit with phone app - PC ...
www.pcadvisor.co.uk/how.../how-fix-broken-fitbit-sync-image-3499292...
May 15, 2015 - Fitbit Flex, Fitbit One, Fitbit Zip, Fitbit Force or Ultra not syncing with the Fitbit app ... To get the Fitbit app sync working again restart the Fitbit tracker. ... charger, has a battery charge but is not lighting up, or isn't tracking your steps. .... I've already done all the obvious stuff: turning off my phone, turning off and ...
Fitbit Flex review - The disappointment we've all been ...
blog.hyperexpert.com/fitbit-flex-review-the-disappointment-weve-all-be...
May 5, 2013 - My wife and I are both in good shape, we both wanted the Flex just to ... app, wait for the device to finish connecting and syncing to your phone, ... to sleep mode, I have to do all of this? and then again to wake it up? .... Also, doesn't the manual say "not" to wear it in the shower? ..... I appreciate any response.
Jan 06, 2016 | Fitbit Flex Wireless Activity & Sleep...
How do I set the time on my fitbit?
After you charge it back up, you will need to sync your Fitbit, this Sync will update the steps
May 20, 2015 | Fitbit Zip Wireless Activity Tracker,...
How do I set the time on a Fitbit Zip?
  • The current time can be viewed on the Fitbit Ultra's display.
  • The time can be displayed in 12 hour format (e.g., 5:00 PM) or 24 hour format (e.g., 17:00). You can adjust this setting on the Edit Profile page, which affects the displayed time on the Fitbit Ultra, graphs, and input fields across the site.
  • The clock display can be disabled from the Fitbit Ultra setup screen.
Feb 15, 2015 | Fitbit Zip Wireless Activity Tracker...
How to set time on fitbit one
The time on your tracker's display may be incorrect due to the timezone being set incorrectly on your profile, or settings not being synced to your tracker. The time displayed on your tracker is configured using the Fitbit.com website.
You can get detailed instructions on updating the time on the Fitbit.com website.
https://help.fitbit.com/customer/portal/articles/1031792-the-time-is-incorrect-on-my-tracker-s-display
Hope that help!
Jul 29, 2014 | Fitbit One Activity Tracker, Burgundy
Need help downloading a fitbit to my hp computer
  1. Go tohttp://www.fitbit.com/setup/and click theDownload Herebutton to download Fitbit Connect for your Force, Flex, One, or Zip tracker. If you have an Ultra, you should instead followthese steps.
  2. Once the download has completed, open the file and begin to follow the onscreen instructions.
    If you are on a Mac, open the dmg file. If it doesn't appear on your desktop, search for "Fitbit Connect" in Spotlight.
    If you are on a PC, run the .exe file from your download location. If it doesn't appear on your desktop, search for "Fitbit Connect" in the Start menu.
  3. Once the installation is complete, you will be presented with the Fitbit Connect Main Menu. SelectSet Up A New Fitbit Device.
  4. Account Setup:
    • SelectNew to Fitbitif you don't already have a Fitbit.com account.
    • SelectExisting Userto log in using your existing Fitbit.com account.
    • ou will be asked for a few details about yourself. This information improves the accuracy of your caloric burn and distance data. You can later adjust yourprivacy settingsto control which details are shared with others.
    • After filling out your personal information, you'll be asked which device you're setting up. Select the appropriate tracker to continue.
    • Plug the wireless USB sync dongle into your computer (this is the smaller USB device--not the charging cable), and bring your tracker near to it to begin pairing.
    • Tracker Pairing:
      • Force, One, or Zip: You will see a pairing number that appears on your tracker's display once your device has been located; enter this number on your computer.
      • Flex: Follow the onscreen instructions and rapidly tap the device when instructed, then confirm its vibration.
    • After clickingNext, your tracker will connect to your Fitbit.com account. This can take up to a minute.
    • Once your tracker has connected to Fitbit.com, you may be prompted to enter a greeting (depending on which tracker you have). This can be your name or any 8-character combination of letters or numbers.
    • When your tracker is linked with your Fitbit account, Fitbit Connect will notify you and present some basic instructions on using your device.
    • You can now log into your account dashboard to view your synced data.
      You will not need to repeat these steps once they have completed--you can simply login tohttp://fitbit.comto access your dashboard.Or Still having Problem Then follow Us For
      HP Support
Apr 24, 2014 | HP Office Equipment & Supplies
Fitbit Zip Wireless Activity Tracker, Midnight Blue Logo
191 people viewed this question
Top Fitbit Tools & Hardware - Others Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Fitbit Tool and Hardware - Other Expert? Answer questions, earn points and help others
